Pikeman
Ok so decided not to do the normal run the wires through the weather stripping as most have done. I bought a 8 pin round Deutsch connector to go through the roof. My original plan was to have it up front next to the sun roof. Well after taking the headliner out I soon realized that wasnt going to happen. I am also going to take the time to put some sound deadening material in with the interior panels out. I only took a few pictures yesterday while making the harness and getting wires run. The pins that go into the connector require a special crimping tool that didnt show up in time so we couldnt actually finish the install. I also installed a 6 fuse buss panel and made a mount for the relays. I will try to take and add more pictures soon but here are a couple for starters. I think the crimpers will show up Monday or Tuesday and will finish the install then. While we were running power we wired for the following lights. Roof rack Outer two with Eurobeam pattern, middle pair pencil/ spot beam, rear facing lights and also relay and switch for my bumper fog/driving lights. I also rerouted power for my HAM radio to the new fuse block.
