smallfry
Currently, I have have a set of Piaa 510's and my CB wired directly to my battery (constant power)and just recently picked up another set of lights and an auxiliary fuse block (to help clean things up).
The plan is to wire both sets of lights and my CB to the fuse block. The question I'm having then is if I'm running the positive and negative feeds (from the lights) to the fuse block how then would I wire up the switches? Would I need to splice the respective wires together or just run a second wire from the respective post to the switch (basically two wires per post)? or do I just have this backwards.
Both sets of lights already have the relays/inline fuses wired in.
The lights are:
PIAA 510's fog lights (already installed)
Lightforce 170's
The fuse block is a Blue Sea 5025 ATO Fuse Block, 6-Circuit with Cover and Negative Bus.
Any help you could all give me would be great.
The lights are:
Lightforce 170's
