Worst stuck stories and pictures
This doesnt involve a 4 runner but here goes...
I used to work for my grand father in law at his steel fabrication business. I did deliveries, and also transported steel from his lower shop to his upper shop (2 miles down the road) to be media blasted prior to paint. I was 20 years old and was driving a brand new 2010 2wd 3500 Chevy flat bed truck, and had nearly 4 tons of angle iron, and plate on the bed, which was probably too much but it was near the end of the day, and I didn't want to make 2 trips...
I get to the shop and I'm trying to burn the rest of the day so he doesn't have me do anything else before I go home, so I decide to drive behind the building through a mud puddle that I had taken that truck through dozens of times prior without problem.... and also without 4 tons of steel on the bed.
As soon as I hit that mud, the 4 rear tire sank up to the bed.... when I mean up to the bed, you could put your heel on the ground, and toe on the bed....
I called the foreman, who then came to get me, so I could personally tell my grandfather in law: owner of the company.. and father and law: president of the company, that I just sank their $75,000 flatbed truck in 4 feet of red clay mud.
So I told them and proceeded to have my anus reamed for the next hour. I continued to work to get that truck out using 2 old ford tractors, and a hyster forklift to no avail. 6 hours later, and 5 hours past time to go home, we still didn't have the truck out. We couldn't remove the steel, because each piece weighed several hundred pounds, and the forklift couldn't reach.
8 hours in, we had to call in his crane operator, who had to use my grandfather in laws $415,000 crane to lift the whole truck out of the mud pit. I had to use a piece of angle iron to dig channels under the truck to attach straps for the crane guy...
The crane operator/fuel/and time came to the tune of $750, a 4 day old truck was filthy, and none of the steel got blasted, welded, or painted, putting us behind for the whole week.
I no longer work there.
So my stuck story was when I was about 16-17.
At that time we had a 1989 Jeep Cherokee Laredo 4x4. So I dropped my Dad and step mother off at the airport on a rainy night. Got back home but stopped at the top of our drive way to make the decision of possibly a better route. At our house, we had a long drive way that was kinda the shape of like a quarter pipe skate board ramp. Off to the right side was a steep grassy hill then kinda leveled out and at that point I would be home free back to the main driveway. So, I hit the fog lights on,switched her into 4wheel drive and made my decent. All of the sudden, I came to a hard stop. So I figured I got hung up on a boulder. So super freaked out at this point, I was able to rock it back and forth off the bolder. Thank god I made it back to my house and never said one word about it. About 10 years later, we sold the Jeep to my uncle. He was the first person I told and he started
laughing out loud and had wondered where the huge scratch on the bottom had come from! Man I'll tell you what, I'll never forget that night...:shocked:
This was me in my FJ heading up from Crystal (almost to the Punch Bowl) on my way to Schofield Pass then to Crested Butte. I was staying fairly close to the edge under the assumption that it was reasonably solid (which I've done many times through this section in the past). Didn't have traction control (ATRAC) enabled since it's really nothing more than a very narrow shelf road until you hit the Punch Bowl. The edge gave way and since I didn't have traction control enabled all the power went to the wheels without traction. The edge under both passenger tires gave way instantly. I stopped immediately. You can see how much the tires slipped down in a matter of seconds. I got out and tested the soil at the edge with my foot and was stunned at how easily it gave way with very little effort (and this was my foot).
This picture gives you a better idea of how precarious the situation was. Another foot or two and my FJ and I would have been in serious jeopardy. We decided it needed to be recovered from the front so I jumped in with one of my buddies and we backed up till we could turn around. We then backtracked through Crystal to Marble, then over McClure Pass and Kebler Pass to Crested Butte. Ate dinner then headed over Schofield Pass and down through the Punch Bowl at midnight in a driving rainstorm. Took us less than 10 minutes to recover the FJ once we got there. Nothing like a little excitement on an otherwise uneventful outing. Learned my lesson about not having traction control enabled on narrow shelf roads in the mountains.
Trying to show off on the river @tripoli rd in Nh (in my recently acquired, bone stock 02' limited) needless to say my rear tires were halfway covered in wet sand and water. I kept dogging myself deeper and deeper, and my dumbass had no idea how to lock the center diff! Hahahah 3 hours later we managed to get her out woth a whole lot of digging...by hand.
I've been off-roading since the mid-70s. So I've had my share of getting stuck incidents, mostly in deep
sand or mud, or high-centered. Sometimes it took hours of work to get unstuck, because I'm usually alone.
The only time I ever got so badly stuck that I couldn't get out on my own, was in 2013. This was when I
had my 2001 Isuzu Trooper.
I was at the Golden Pen mine in Nevada, which is located high on the side of a desert mountain. The original
road past the mine and into the bunkhouse site, was cut off by a landslide or washout. The newer trail comes
in over a ridge.
As I began to leave, I missed the newer route and took the original trail by mistake. It goes around the hill
for about a half mile until it gets to the washout. The trail is very narrow, with a vertical embankment on the
uphill side and a steep drop on the downhill side. There were no wide spots at all to turn around, so I had to
back it slowly around the hill. This would have been a lot easier with the 4Runner's backup camera!
I got almost all the way back to where I'd started, but ended up too close to the edge and it collapsed. Both
wheels on the passenger side went over, and the Trooper was hung up. Even with the limited-slip differential,
there wasn't enough traction anywhere to do anything but spin the wheels:
Fortunately I had a rented satellite phone, and used it to call 911. The 911 operator contacted the Mineral
County Sheriff's department, and they sent out Search and Rescue. I had no idea what that would entail,
but it turned out to be a volunteer group of off-roaders. Four vehicles arrived, and the guy with the biggest
truck positioned it on the hillside above the trail, and winched the Trooper up onto the trail.
<iframe width="560" height="315" src="https://www.youtube.com/embed/z0wqde1hp2A?ecver=1" frameborder="0" allowfullscreen></iframe>
in over a ridge.
You called 911 because you got stuck while purposely off-roading?
What was the emergency that warranted the call?
Nobody I spoke with at 911, the sheriff's office, or the search & rescue people, felt my call was unwarranted.
But I'm open to suggestions, if you have anything positive to offer. Who would you call in that situation? Bear
in mind that it's the desert, in summer, with no cell service, no internet, no phonebook, and the nearest town
is a 3-4 day hike away.
This Thread...
This thread makes me happy I have owned my 4Runner since it was new lol.
This thread makes me not want to buy used 4x4s.
This thread makes me happy I wheel in dry sandy deserts.
The swamp people stuff is too next level for me lol. I really hate mud and water.
No pictures for my story, I was too busy trying not to die in 105-110F heat while I had my truck sitting on the frame in the desert from trying to recover someone else.
It was an inexpensive but valuable lesson on recovery and why its always better to be prepared with quality gear and not need it, than wish you had it at the worst possible time.
Always keep water in your truck and buy the best recovery gear you can afford. It seems a lot cheaper when you actually need it lol.
Bring more than 1 shovel so your passengers can dig too.
I don't see a lot of difference in this situation than if a hiker gets lost while "purposely" going into the backcountry. S&R folks would much rather rescue live people than recover bodies. Sounds to me like a rational and appropriate call for help.
Just a comment on backing up on narrow roads or tight spots. It looks like, from the picture, that you inadvertently backed off the road. In those situations, it's worth while to adjust your side mirrors down so you can see the road beside your rear wheels, and tell immediately if you're getting too close to the edge. Useful for 3 or 5 point turns on tight switchbacks as well. Maybe you already know and did this, but I thought I would share it.
I would have probably hit up my local repeaters and requested help from some locals, or had them relay a message to someone like a specialty tow service.
My local deserts are very well covered by repeater towers so communications even when nothing else works is not a problem. Plenty of users on the network who also off-road the same lands.
At least have one licenced ham radio operator in the group when you go off-grid.
I have done multiple off-road off-grip camping trips where my ham radio was literally my only form of reliable communication to the outside world.
The amount of saftey and piece of mind you get having a ham radio licence is awesome. Its $15 and its good for 10 years and all you need to do is take a little time to pass a multiple choice test.
Just get a small radio like this... most people think its some type of CB radio but its literally that much better. Its like comparing pagers to smart phones. Today digital ham radio gear can send voice, data, and gps over radio with the option for internet linking if you need to extend beyond a radio coverage range which can generally be hundreds of miles from even something as simple as a handheld.
My wife who also has a licence once went snowboarding in Utah and from to top of a mountain with absolutely no cellular coverage was having a conversation with me while I was home in CA. Really puts me at ease when she has that type of capability in her jacket pocket.
I even have a portable communications kit with solar and a repeater that I use for disaster preparedness, search and rescue, and just car to car communications with friends when on those more hard core off-road adventures.
Good call.
Must be Southern California. J.T.? Anza Borrego? Somewhere near I15 or I10?
Lots of wilderness lands and national parks in the north, where installation of towers can be difficult. I followed the effort to get a tower installed on the Darwin Plateau, above Saline Valley, and seems like it only got done because the military wanted something there.
Then again, I don't know jack about radio tech. I do know the desert. And 3-4 days of hiking out can be a serious problem, considering that the fatal exposure time around Stovepipe Wells on a hot day is about an hour. Even if you are carrying a water bottle:
https://deathvalley.com/dvtalkarc5/messages/8990.shtml
Granted, the guy was 80, but there have also been incidents at the same dunes involving much younger people who thought if they brought enough water, only a 1.5 mile hike, that they'd be ok. And they died.
Yup... spot on. Anza Borrego and other BLM lands off the 8 freeway like Ocotillo Wells, Superstition Mountain. I know my deserts as well but that can be dangerous too. I feel like I know enough to get myself into a little trouble.
Also a bit further up north like Jawbone Canyon, RedRock, and Alabama Hills off the 395.
Generally speaking if I am going somewhere new and I don't have repeater data I make sure I get before venturing out. Before going off-road but soon after getting off the freeway I stop and use my ReaeaterBook application which uses GPS. I screen shot everything within a 50-100 mile radius just so I have it on my phone.
https://itunes.apple.com/us/app/repeaterbook/id606820166?mt=8
I also ALWAYS have a paper repeater directory in the 4Runner glove box for emergency too.
https://www.amazon.com/ARRL-Repeate...&qid=1493234880&sr=8-1&keywords=repeater+book
I did a road trip from SoCal to Oregon and back by myself, camping along the way, "living off the land" lol... I totally get what you are saying about repeater access up north. One of the trips was to mendocino national forest and it was pretty dark even for radio communications.
There was no way to get coms using a handheld radio and I needed to be on foot and not tied to the truck. I had to setup the repeater so I could talk to my 4Runner from my handheld which then rebroadcast the transmission at full power. Without that I would have been completely alone and without help. Kinda scary when you are going solo.
I heard about that Death Valley story as well... and I have been in that type of heat with a stranded truck before. Its no joke, and on top of that I had to dig out my truck which was sitting on the frame. The danger is real and the heat exhaustion comes fast. I was literally constantly drinking water, you couldn't get it into you fast enough when working. Very unforgiving place and you learn to respect it in a different way with experiences like that.
If you want to learn more about ham radio stuff then join a ham forum, or just call Ham Radio Outlet and they can guide you in the right direction for both testing and equipment. Once you own it, you own it. There is no month fee like a cell or sat phone.
Ham Radio Outlet
Get a study guide from the library for free, take the test, buy a radio and learn how to use it. Its probably one of the most valuable tools I have ever taken off-road.
I just hate being in a recovery situation and feeling helpless... a fun day wheeling can get real, real fast.
Great story. Thanks for sharing. (Ignore the wanna-be trolls)
in over a ridge.
