golfing4lf
I'm new here. I had an FJ cruiser and sold it and miss the toyota. I've been looking at a few different 4runners in the area, from 96-99 mostly and came across this and want the opinion of y'all.
97 5spd with 200k on it. Owner just did a head job due to blown head gasket, machined the heads, new gaskets, replaced bad valves and resurfaced others. has new timing belt, water pump, clutch, new front brakes. also has e-locker.
he's asking 3500 for the truck, interior is dirty, not a concern to me as i will most likely bedline the floor.
Is there anything I should look out for? Anything that jumps out to you all? I'm going to look at the truck for the first time tomorrow. I know most of what to look for as far as rust underneath, etc. Just not so sure about buying something that has had all this work done, but then again, the truck should be ready to go for a long while now.
Any specific questions I should ask him about the recent work? Check engine light is on - code is for IAC valve, he stated cold idle is around 1500, the drops to 1000. Should this be a major concern.
Any help is appreciated. Looking forward to this new adventure. oh, and this will be a daily driver.
