Worth doing head gasket again?
FudgeYes
Hello forum.
Due to some kind of blockage in my cooling system, my truck overheated unexpectedly.
It was fine for a while,then on a sudden glance to my temp guage, I noticed a HUGE spike in temperature and immediately pulled over.
Head gasket was already blown by that point.
The issue is, this will be the SECOND time this engine has had a head gasket done, and I don't know how hot it got back then.
It also had its heads sent to a machine shop then.
I know that I got it to at least 250-260+ f since the needle was so high.
When starting it again it runs really well, like it did before the gasket blew.
Are these blocks known to warp?
Could I potentially just get the heads/block checked for flatness and go from there?
How do you know the head gasket is blown? Did you do a hydrocarbon or compression test? These engines are pretty tough. What caused the overheat?
I think it's safe to say that any block can warp at temperatures that high. I'm sure you can get the heads checked but it's going to require a tear down, which at that point, you might as well do the HG again or just throw new/used ones in the there.
What's leading you to believe that you blew the head gasket again? And why is this the second time it's happened now? Is there a deeper issue that's not being addressed with your engine?
Sent from my SM-S908U using Tapatalk
AndiGarage
