I'm no stranger to breathing new life into cars and trucks. I knew this one would need some work, but was thinking I could turn it into a pretty nice 4th gen with a little cash and a lot of sweat equity. I can get it for $4500.
I went and test drove it recently. 1st 4th gen I've ever driven. Seemed fine for the most part. I was expecting better acceleration but that may be due to the weight of the factory 20s and larger than original tires which rubbed a bit when turning. The ABS, VSC, traction control lights are on, which from what i've gathered is a faulty brake light switch. Other things of note are: It was a one owner until seller purchased from his boss with the intention of building it up but changed his mind as he has 3 other vehicles. 175k miles and needs a timing belt. Looks like it lived outside most of its life as the hood and roof have failed clearcoat and feel like sand paper. Fender flares could use some paint too. Could get away with that but could use a whole paint job. Leather is in pretty good shape with no rips or tears but carpet needs replacing. Headlight housings are cracked from sun exposure. Sunroof has been silicone sealed shut and "doesn't leak". Dash is cracked. No rust other than surface in 2 spots where the carpet was worn through.
My plan would be:
Brake light switch $30
Coverlay vinyl dash cover $170
Carpet replacement $250
Sell factory 20s and get 17s with 275 70s $1700
Fix sunroof $0-?
Have at least hood, roof and fender flares professionally painted $500
Lift $500ish
So around $7500- $8k
What do you guys think?
My plan would be:
Fix sunroof $0-?
Lift $500ish
