wreckedrex's build log
wreckedrex
So I just picked up this '96 and I'm planing to do some minor mods to set it as a camping rig. Nothing nuts, and probably nothing that hasn't been seen a million times so far, but I figure I can use this thread to track progress and maybe have some more experienced eyes than my own point out anything really stupid. It's going to be my daily for a few years and the off road use, while probably somewhat frequent, will be fairly light duty trail running. 31-32" tires are more than adequate, no armor required.
As purchsed:
A bit of info on the truck; it's a 3.4/auto 4x4 with ~148k on the clock. Total stripper, near as I can tell. No sunroof, no flares, cloth... Real basic.
The good:
AC is cold
Stereo is decent
runs like a top
shifts smooth and quick
The bad:
The paint is toast
Drives seat is destroyed
Tires are shot
shocks are shot
15" wheels (only bad because I want to do the tundra brake swap.)
And the to-do list:
Maintenance:
I didn't get any reciepts other than for a recent plug/wire/coil pack replacement so I am going to have to go through it from tip to tail. Not really a problem, I'll feel better about it if I know I have had my hands in there. Good way to get to know a new truck anyway. Initial list:
air filter
PCV
coolant (clean and fresh, leaving alone)
Oil (looks peachy, but I'll change it soon anyway)
diffs
trans fluid/filter (probably try and do an aux cooler at the same time)
tcase
hit the zerks
Rear axle seals (drivers side drum is a mess, it's time)
Valve cover gaskets (nothings hitting the ground yet, but it's pretty grimy in there)
Timing belt (PO said it was done @120k, but I want to at least get the covers off and take a peek for myself)
Repairs:
Drivers seat. (Dear god, a new drivers seat! Should i be looking for anything specific? which trucks had the best seats? Had STI seats in my old pickup, I guess I could do something like that again.)
Center console. (beat up around the shifter, not critical. little indicator tick mark doesn't work, rattles a little. WAY down the list)
FM Antenna. (power one that's on it is broken off. Thinking about deleting it and sticking a small powered one under the dash. Pretty cheap, and the one in my brother's truck seems to work fine.) Done, used a $25 Metra part.
Fun stuff:
Mild lift. (OME 880/906 + shocks and a diff drop on order at Toytec. Normally I'd wait on this, but the stock parts are roached and it rides like crap)
Tires/wheels. (Already picked up a set of taco wheels (pictured) and was planning to throw a set of 265/75 TA KOs on them, but it seems I may have a backspacing issue... I dig the wheels, and it seems that some folks have the tires I want work without spacers, but it looks real close. Thoughts?)
Lights. (thinking halogen here, like Hella 500? not a ton of $$ to spend here)
Traction (thinking elocker conversion based on price alone... Not exactly a need, but I want one)
Sound deadening (Cruiser Crap's Quietcrap most likely, can by in bulk since my brother and I will probably do both our runners at the same time)
Sleeping platform/storage (probably something really basic here, for now I'll just be folding seats and throwing down my camp mats.)
Tundra brakes (I know how and where I drive... Based on what I've read so far I'll be needing this upgrade in short order.)
CB (easy and cheap enough, ordered an antenna brkt with the suspension parts.)
Running board delete (easy, probably do it this afternoon...)
As it sits:
It's replacing my '93 pickup with a softopper. Loved to hate that thing, amazing little truck ruined by the 3.0.
Paint them wheels a darker color! :D
Maybe consider seafoaming the pcv and crankcase, gas tank before the oil change.
Lower ball joints, too. Uppers too if you have the time/patience. Perhaps get a braided line for the rubber section of brake line for when you do the 13WL upgrade. I'm going that route (parts delivered today/Monday!!)
Grabbed a quick pic showing my possible backspacing issue:
The tire is a 245/75, so ~30.5" tall, a 265/75 moves the the wide point about 1/2" up (half the diameter gain) and 1/2" (half of the width increase) over towards the control arm/balljoint... Seems like it's getting awfully close. May try a set of 235/85 ta ko, a little taller and should clear without issue. I kinda dig the pizza cutter look anyway.
Another showing why I went with the suspension first:
She's very nearly ridding on the bump stops. Really harsh, but on the plus side there's almost no body roll! Also shows how bad the left axle seal is.
I'm thinking a medium grey for the wheels, eventually. If I keep them, that is.
How bad are the upper ball joints to do? I'm assuming the arms have got to come off and new parts are pressed in. I know the lowers need to be done, but they're a bolt in deal. I'll get 'em on order and do them when I do the lift.
The pressing out/in is the hard part. After seeing guys who've worked on their trucks a lot comment that it was a PITA, it has me a bit daunted...
Running board delete done, much better:
Did the antenna too, threw a Metra powered antenna in the dash and ripped the power unit out of the fender. ~$25 and an hour or so and I have reception, much better. I replaced a dead hvac control bulb while I was in there. Minor problem, but annoying in an unfamiliar car... The green bulb condoms failed, so i sprayed them red with some old tint paint I had around. I'll see how it looks once it gets dark, but I generally prefer red lighting for vision. If it works I'll do the instrument cluster the same way.
Progress!
Got taller jackstands:
Used said jackstands to get the old junk out and the new OME goodies installed:
How she sits presently:
I'm really happy with the ride, but anything would be a massive improvement over the blown out and sagged stuff that was on it. The shocks were toast, and the rear would slam into the bump stops at the slightest hint of an impact.
Also got the trans cooler and a new radiator installed:
It's a Hayden 678, supposedly a the same part as the TRD unit. At least according to the internet, I'm taking that with a grain of salt. Either way, it seems like a quality part and I got it for $36 from Oreilly's. I'd initially installed it with the zip ties that came in the kit, but decided to remount it with some brackets I hacked up from aluminum strip.
Next up will should be tires, they were supposed to go on last week but I wasn't able to get the truck to the shop. Hopefully I'll get it taken care of this afternoon.
Long overdue update:
Truck was rear ended while I was headed to the tire shop, a kid in a Camry hit an Accord and shoved it into me at a light. Damage was fairly light, but it ripped the seat right out of the floor pan so the insurance company totaled it. On the bright side, I got a sweet rental for the weekend and they wrote me a check for $1500 more than I paid for the truck, including the $225 they charged me to keep it! A couple of bucks in parts (literally, just a few screws!), lots persuasion-by-hammer, some swearing, and some time at the DMV and I now have a truck that I am being paid to drive :cheers: She's a bit uglier, but you can't beat the price!
Only pic I bothered to grab of the damage, apparently:
Pic of sweet rental:
Pic of said rental on trail
What an awesome truck, loved that thing. No, really, it was great! I went into the deal as a joke, knowing I'd hate it. I was supposed to go run some trails and camp with my uncle (a jeeper, drives an old Cj5) that weekend and figured if I couldn't play with my truck at least showing up in this thing would be good for a laugh or two. I did get a few chuckles and a couple of weird looks, but it turns out it's one of the better things I've ever driven. I want one. Steaming heaps of power, surprisingly good fuel economy, incredibly good to drive, and supremely comfortable. My only gripe is the clunky infotainment system, it's... Well, clunky at best.
Here's pic from this weekend, with the new skinny tires and a pair of fogs:
I'm still really happy with the OME suspension. It's a bit firmer than I'd like off pavement, but it's not a marshmallow over the road. It's a trade off I'm ok with.
044runner4
