wrung off a lug nut stud.... how to fix?
zimm
Rotated my tires today. Set the torque wrench to 100 ft/lbs and the stud just came off like it was taffy. Crap. I tried another and the same thing- it just kept turning. So I backed it down to 80 ft/lbs and the other 3 wheels did just fine. So how about putting new studs in the one front hub? I need to do new pads and rotors anyway, are the studs in the rotor or behind it?
Did the same thing on my Tacoma, I think the studs are behind.
Take off the breaks, (rotor too) and I think there is a backing dust cover, that that off if there is a bring out the big boy hammer! :biggrin2:
Thanks for the inputs! I'm sure one of the tire shops probably over torqued them with an air wrench in the past.
I'll get some new studs and lug nuts. I read that I can just punch out the stud without having to remove the hub- that's good news.
That's correct. I had to do 3 of them from a screw up. You can get them at NAPA, that's where I got mine and I think it was 5.00 for 2 lugs and studs, not completely sure. Its relatively cheap though.
Thanks, I'll make the trek to napa then. OEM toyota online prices are $5.85 per nut and $2.86 per stud. So.... $9 x 6 = expensive.
