WTB 2nd gen rear coil springs
Not sure what I need exactly, I don't know squat about 2nd gens or their coil springs. If you would school me on any differences in the 2nd gen springs.
Well the reason everybody swaps them out is that they are notorious for sagging in the rear. That is the reason I swapped mine out with a set of old man emu springs to alleviate the rear sag in my second gen. If you are looking to raise the rear a stock set is problably not what you want.
What I am doing is putting a 80 series Land Cruiser axle in my 3rd gen 4runner.
Due to the center to center dimension of the spring perches on the axle I am having to put a plate under the frame rail and use that for my coil bucket to keep the springs straight up and down. I can't use the factory location.
The way I am having to lower the top spring mounting from about the top of the frame rail to about an inch below the frame rail would be like putting a 4 inch spacer on top of the springs.
If I compress the spring more than it was in the 2nd gen might be a good thing in this case because it will give me more axle down travel, granted I will loose some up travel.
About how much sag did the 2nd gen springs develop?
Hope all that makes sense and thanks for the help.
