If you plan to post to Classified forums, you must follow these rules, or your post will be deleted.
snomobo said:Its the factory 6-disc in-dash changer/radio that came with my Sport.
Spider5 said:How would that work if I have the single disk unit without the amp in the rear panel. I don't think you can even hook up the speakers without the amp can you?
PatrickB said:I am in process of going through the same swap. It's great for someone with a single disc JBL system that would like to upgrade to the changer without having to go with one mounted in the glove box or center console.
Also, from what I've found out, the 6-disc includes RDS too and the knobs are larger and match the same design around the gauges on my SE.
If you have a limited, you'll probably have a harder time finding someone... and you can't swap between a limited and SR5 or SE.
Spider5 said:I'm also interested but like I asked before, how are you doing this without the amp in the back as part of the swap?
sharp4runr said:He has the single disc JBL, so he already has an amp and all the wiring needed. Its just a matter of swapping head units, trim bezels and possibley the trip computer/face plate.
