WTB/Trade: 04 6disc unit and bezel
snomobo
Looking to trade someone their single disc radio bezel in exchange for a 6disc bezel and I'll throw in the 6disc unit. Already have navi unit and need surrounding center panel display and computer bezel unit to get factory look.
Located in DC area!
Sno
snomobo said:
Its the factory 6-disc in-dash changer/radio that came with my Sport.
How would that work if I have the single disk unit without the amp in the rear panel. I don't think you can even hook up the speakers without the amp can you?
I believe this is the JBL 6 Disc in dash changer and it requires the external amp to function properly. If you have the standard radio, it will not be a direct replacement.
snomobo - I went through a similar swap and document as best I could here. Hope it helps: http://www.toyota-4runner.org/showthread.php?s=&threadid=9821&highlight=swap+jbl+unit
I am in process of going through the same swap. It's great for someone with a single disc JBL system that would like to upgrade to the changer without having to go with one mounted in the glove box or center console.
Also, from what I've found out, the 6-disc includes RDS too and the knobs are larger and match the same design around the gauges on my SE.
If you have a limited, you'll probably have a harder time finding someone... and you can't swap between a limited and SR5 or SE.
I'm also interested but like I asked before, how are you doing this without the amp in the back as part of the swap?
He has the single disc JBL, so he already has an amp and all the wiring needed. Its just a matter of swapping head units, trim bezels and possibley the trip computer/face plate.
I didn't know they are compatible. Thanks for the clarification
