WTS - Headrest, Master Cylinder, and Bi-Xenon Projectors
etc.
Member
All items are off a 1997 4runner Limited.
First is an extra front headrest that I have. No rips or tears. Great condition for what it is. $10 +shipping
Second is an OEM master cylinder. I replaced it due to a soft pedal, but was probably due to old fluid. Doesn't leak and could use a soft exterior cleaning. Perfect for a rebuild. $10 + shipping
*****PROJECTORS SOLD
And lastly is a projector retrofit using Morimoto Projectors, bulbs and wiring harness.
Bi-xenon Morimoto Mini Stage III Kit (D2S) - Complete Retrofit Kits from The Retrofit Source Inc
Mini D2S Stage III:
*3Five watt ballasts
*Color - 5K
*H4 bulb relay
*E46-R Ext shrouds
Complete harness + 3Five ballasts
Harness
Projectors + Shrouds
Scratch - Just above center.
Scratch - 12 o'clock
Bulb - Broken tab
Bulb - Broken tab
These will be sold without the buckets. After removing them, I came to the conclusion that they should be in the garbage, not on a vehicle.
The bulbs have one broken tab on each bulb. Doesnt hurt performance, but should be noted.
The lenses on the projectors have 1 scratch on each lens. Again, doesnt hurt performance, but should be noted.
$165+ shipping.
So are you selling just the components for the retrofit, or are you including the headlights to put them in as well? Thanks.
I have a pair of headlights available for sale in the event you end up buying just those components for the retrofit...
I may end up taking you up on that offer, are they 99+ clear ones? Heck I may end up picking those up even if I don't get the retrofit, anything would be an improvement over the stock frosted glass 98 lights.
yes, they are clear JDMs, I can send you photos...
tobasko556
