X-REAS shocks and springs for sale
Dbadtoy2
X-REAS shocks for sale... All they disconnected at the correct location. Also have the stock Sport springs...44k miles on everthing...Make offer...
These are off my buddys truck he went with the Toytec Ultimate lift. We put it on this past weekend...I am still up in the air about what I want to go with.
I need a set of XREAS shocks for my 2003 4runner limited. Mine started leaking. Do you still have them and would yours fit a 2003?
I have a full set from my truck (57k) but it's still on it till I switch to a different setup or should I say when I switch to a new setup. I'm not sure how much they're going for used but if I can get at least some $ on them to offset the cost of a new setup then we might be able to make a deal.
BTW, AMISBOB, how many miles do you have on your 2003?
njharrell: I think the dilemma you will face is finding a full set to begin with and then having it shipped to you. The whole set is strange to ship because you cannot bend the lines.
It looks like you have the FJC bilsteins on your 2003 4R, why do you want the XREAS? Anything wrong with the bilsteins?
Okay, got ya. No, I am happy with the bilsteins, but brother had a sport and i loved the way his rode. But it sounds like it's not worth the trouble...
I have 80K on my 4runner. I noticed that right front shock is leaking. Trying to find an inexpensive way to replace them.
80k and a leak already? Wow, I've read some users having over 100k on them with no problems. I'm actually looking to upgrade to a beefier setup, ready to sacrifice the no lean during turns ride to get a more off road capable truck. If and when I finally do do it and you still need em I'll let you know.
No Lean
Ronsta,
Your handling will improve the day your remove your XREAS and install Bilsteins. Your T4R will lean LESS in the turns. If, in addition, you do the poly end link upgrade you will notice an even bigger improvement in handling.
Ronsta,
Actually I'm worried that the truck will start to lean during turns after I remove the XREAS. I can truthfully say that on hard ball the truck feels like a sedan when going through turns & I think its b/c of the XREAS so if I take that off then I'll need to slow down at the on/off ramps. The benefit I'm hoping to gain is better off road ability.
My apologies to Dbadtoy2 for taking this OT...Again.
Quote:
Originally Posted by fast325it
Ronsta,
I'm not sure you are understanding my post above. Your truck will handle BETTER without XREAS if you replace it with Bilstein shocks. I've done the mod myself as have many others. My truck, with XREAS removed and Bilsteins installed, will out corner and out handle your truck with XREAS still installed. You will drive FASTER on the off ramps and have LESS brake dive with Bilsteins. Your truck with Bilsteins installed will have less of the side-to-side wiggle the T4R is known for when driving over uneven pavement. And, while towing a trailer, you will again have confidance that the T4R will travel in a straight line on the freeway. It's a good mod done by many T4R owners and you will not be disappointed. Your truck however, will ride more like a truck. The ride will be firmer and the bumps more obvious.
XREAS was a good attempt by Toyota to make a truck ride like a car and handle like a car however, it misses by a mile when compared to a high quality aftermarket shock. I can't speak of off road ability comparisons however, I would assume your truck's off road manors will IMPROVE without XREAS. Read the threads. No real T4R off roader is still using XREAS.
