**XenonDepot SPRING FEVER SUPER SALE!!
XenonDepot
Xtreme HID Kits ON SALE!! - Only $199.99*
LOWEST PRICE EVER OFFERED ON THESE KITS!!
* Authorized toyota-4runner.og vendor!
* Selling Quality lighting products since 2001!!
* OEM Grade components!
* Full replacement warranty!
* Trained & Knowledgeable Staff!
* We will NOT sacrifice quality!
The Xtreme HID Conversion kits utilize cutting edge HID components made with superior Japanese craftsmanship and quality. These kits are manufactured in a high tech facility that is ISO and TUV certified!! Laser calibrated bulbs are used to ensure proper fitment and optically correct beam patterns. Don't sacrifice quality when it comes to your car!
The ballasts used in this product are uniquely designed for aftermarket applications as they are completely epoxy sealed to protect against harsh weather conditions. In aftermarket applications, ballasts are often mounted outside the headlight leaving them susceptible to water damage. The Xtreme ballasts are specifically designed for these applications making them the superior choice for your aftermarket HID upgrade.
BALLAST SPECIFICATIONS:
- Xtreme HID ballasts are designed with a patented multi stage safety feedback (M.S.S.F.) system allowing them to interact with the bulbs to determine optimal light output.
- Xtreme HID ballasts use a patented self intelligent light output configuration (S.I.L.C) to ensure brightness stability and precise illumination colour.
- The Xtreme HID ballasts are designed for both 12V and 24V applications.
- Equipped with advanced polarity protection system
This product will include 2 complete wiring harnesses - 1 per side that will literally plug directly into your OEM headlight harnesses via proper mating connectors. The harnesses provided will include upgraded fuses and relays to ensure you do not draw a higher current from your stock wiring harness than it was designed to provide. Unlike many kits on the market, each harness will be completely independent of the other so should a fuse ever fail, you will still have a functioning headlight. Most other HID kits that come with a harness use a single relay/fuse design that will result in you losing both your headlights if the harness fails.
Please click here for some non biased reviews and customer testimonials:
http://www.kbcarstuff.com/SearchResults.asp?Cat=61
Our products are backed by a one year warranty. A warranty is only good as long as your vendor stays in business. We have been selling HID kits since 2001 and have been a reliable vendor on this forum as well. Our goal is to offer our customers quality lighting products with a higher level of support/service!!
Please enter this coupon code to obtain your discounted price upon checkout: T4R
Make your installation safe! Get a FREE pair of Nylon Nitrile dipped gloves!!!
The ideal glove for installing our HID lighting products!
To those of you that don't already know me, if you have any questions/conerns please feel free to PM me or send me an email to [email protected]
**All orders placed at this discounted price will still be included in our monthly draw to win a free HID conversion kit
Regards,
Steve
PS I know you will ask so yes, H11 4300k and 5000k kits in stock (most popular sellers on this board).
Just thought I would add in this picture showing exactly how are ballasts are designed specifically for aftermarket HID applications:
This epoxy seals the ballast and helps protect against harsh weather conditions.
Steve
Hi Guys,
I have gotten some questions from people asking if this promo is still on so just adding in that this promo is currently on until the end of this month.
Steve
I'd love Phillips kit, but @ 290.00 USD its little steep considering the competition prices. Let us know if there is a sale this fall.
Hi,
With the T4R coupon code the price drops down to $259.99.
Philips bulbs are expensive. The price of one Philips bulb is more expensive than a complete HID conversion kit that is made in China.
We also have the Xtreme H11 4300k kit that uses our Japanese bulbs and ballasts for $199.99.
Steve
Hi,
Once you add your item to the shopping cart you will be forwarded to a checkout page. You will see a spot to enter a coupon code. Please enter this code - T4R
You will see that a $25 discount will pop up.
All H11 and 9006 kits are in stock so they will ship right away.
Steve
Couldn't be happier with my XenonDepot HIDs, these things were a snap to install and couldn't have turned out any better. (Unless of course I had projector lamps instead of reflector :p)
Reading through the 'GotHID?' group buy thread nightmare makes me glad i spent a little extra on these, they're worth every penny!
:biggrin2:
Glad to hear you're happy with the product =)
While I wish I could compete with the other pricing there is no way that I can given that our cost on the product is significantly higher. We are in this for the long run. We have been selling HID conversion kits for 7 years now and going strong! We're not looking to make a quick buck of some forum members and then fade away.
Steve
I've standart (non-HID) headlights. Will HID kit work with out projector lamps safely? And more importantly, will it melt my lense and housing?
Hi,
As per your questions:
1) We have had many members on this board install the kit in reflective headlights with very positive results. cjjackson85 just responded about how he is happy with the product and it is installed in a reflective headlight.
2) Our kit will come with a proper relay harness that will power the ballasts directly from the battery. All you will use your OEm headlight harness for is simply to trigger the lights on/off. With the harness installed you do not run the risk of damaging your OE wiring.
Regards,
Steve
