Xhorse mongoose Techstream for US$29.99
My curiosity is sparked for sure.
Thanks for checking.
I guess you could always run the thing in a sandbox too.
Are you able to read live data with this cable? I have a $20 ebay one and it fails to read. I am able to make adjustments in the customize section though.
All MVCI drivers throw the antivirus warning. I normally disable it while I'm using Techstream.
Yes, it can read live data, I tried 2 times,and it can always work.
This one is only 23.99USD, seems to be copy one, not Xhorse product. What I used is Xhorse product, what it can do? and can't do? Can it read live data?
Have not received the cable yet.
Just ordered it when I posted.
Once I get it, I will update as to what functions it can do.
TIS Techstream V9.30.002
Today I see they have TIS Techstream V9.30.002, I am informed the software interface supports Techstream (Mongoose, miniVCI, MVCI, Openport 2.0, AVDI, CarDAQ etc.)
Hhmm...how can I reduce the noises?
Remove headers from exhaust manifold, drive around, reinstall headers. Is this like a trick question, or something? What does it have to do with techstream?
Crawl under vehicle and look for exhaust leaks, excessive rust, and loose heat shields.
Drop to $ 21
Got email from uobd2. Price of the Chinese Xhorse Toyota TIS Techstream has dropped to about $ 21 from Nov.21 to Nov.27, 6% off for Thanksgiving sale, with coupon code: THANKS. :lol:
techstream V10.10.018
Got one mini vci by Xhorse running techstream V10.10.018. Verified running well.
Bought from: New MINI VCI For TOYOTA TIS Techstream V10.10.018 16Pin Cable
USB port plugs to laptop, the other end goes to the OBD2 port. I was advised better run techstream on old computer running windows XP, but I run at XP Mode in Win7 pro, it works.
Techstream V10.10.018 installation is simple, no need to active.
1) Install TOYOTA TIS Techstream
2) Install MCVI driver
3) Click "MVCI Firmware Update Tool" on the desktop to read out device detailed info including SN, model, firmware version, dealer code, status.
4) Finally, click "Techstream" on the desktop to diagnose, read out fault code, datastream.
Then, I got techstream working on 2015 TEP, Worked on 2015 Trail.
hello i follow your link and find i can not find it . finally i find uobd2.net update to uobdii.com the newest link is :
MINI VCI FOR TOYOTA TIS Techstream Firmware V2.0.4 Single Cable Support VPW protocol
leolediola
