XREAS broken?
harojs
How does a broken XREAS system show itself?
I have a 2006 Sport and XREAS seems ok.
Just want to know what to look for if XREAS begins to fail.
John
Bellevue, WA
Sent from my SM-G920V using Tapatalk
John
Bellevue, WA
You’ll have to crawl under the truck and look for hydraulic fluid leaking from the shocks and struts. Mine was way overdue and I could hear and feel a “KERTHUNK” noise whenever I went over speed bumps or any uneven stuff
You will know you have a failed Xreas when you go ahead and replace it and see just how bad it really was.:thumb3:
My X-REAS failed on my 03 Limited at 138,000 km. There was a leak in the system - in the line behind the Driver’s Side Centre Control Absorber. Leak was likely caused by corrosion of the line due to road salt used up here during our Canadian winters.
Fluid that had dripped onto the driveway was the first indicator of some sort of problem. As more fluid leaked out of the system, the suspension became worse.
I removed the entire X-REAS system (too costly to replace), and installed the standard SR5 suspension (to keep it relatively stock).
Do you have the full parts list that you needed to buy? Seems every time I read about the suspension being changed I can't find a full parts list and I know nothing about suspension so thought it would help if I had a definitive list.
Just replaced my XREAS system last month. Rear shock were leaking and fronts provided little support as I seemed to skip while driving on asphalt. I cut out the XREAS lines and replaced it all with Bilstein 5100s in the front and rear. The fronts were set to compensate for the height lost when removing the coil spacers. The rear spacers were left in place.
DJNutshell
