ddd269 said:Hello guys. I encountered a minor problem. <--- huge understatement
I got my cornfed 3
trijicon said:Ahhhh I'm sorry ddd269. I hope it turns out okay
I am about to order a 2" cornfed kit from burtman and had also thought about having a shop do the install. I'm scared the same thing will happen to my install.
So what is the best way to explain the install to a shop? Tell them to not to disconnect the Xreas lines? What else should be told to a shop when dealing with Xreas? and tips?
I'm sure most shops are oblivious to an Xreas system. How can I make sure they don't screw up the install??
ddd269 said:The cornfed includes clear instructions for XREAS 4runners. it's just a matter of following/reading instructions! Is not brain surgery. The reason I did it at my local Firestone is because I have a life-time alignment. Since I have to do one after the lift... you know.
Just tell the mech not to mess with the line.
...or do it yourself. I would have done it with the forum gang, but I can't make it this weekend.
btw... oblivious is about right. Actually it's more like "never heard of it", that is including the dealers. I've called 7 different dealers and most didn't know about it, put me on hold to find someone that knew or didn't have time to talk to me. Of the 7 that I called, only one had some experience with it. They'll call me back tomorrow. Is this system such a mystery?
Good Times said:If you get the TSM (Toyota Service Manual) it clearly states how to disconnect and reconnect a XREAS system. So atleast you know you can do it yourself safely.
I know someone that has taken off the xreas system (completely) and then reinstalled it with no ill effect. So atleast you know it can be done safely.
Good luck
