Xreas Removal help needed
Brutalguyracing
i am just looking to trash this system the easy way
i have seen the write up on proper removal
but i would like to just chop this crap outa my way
whats the most effective way to drain all fluid at once......
Cut a line like I did!! :D It'll spray a little fluid, but just let it bleed and keep chopping!!! :whip2:
Can't you just disconnect the shocks/struts at the disconnect points and leave the lines alone? Probably the easiest way to go about it.
will just one cut do it?
what about just removing the bolt on the front shocks
did this for a sec today and got fluid in my face and the driveway and had to stop
everything needs to go
i need to weld my sliders on one day too
its such a pain in the azz
i wanted to install my coilovers today
but wont have time to do the reaRS errrr i hate the system
If you start on the front you will get the leaking on each side as they make an X underneath your truck. I just cut that rubber part on mine, but mine were blown and leaking already so they didn't make much of a mess. lol
You can unbolt them at the correct spots and it won't leak, but where's the fun in that??!! :D
Have you seen where them spots are located
My truck is so saggy its crazy
Was hoping in had no fluid left
But dam was i wrong
But dam was i wrong
I don't know where a pic is, but it is between the to fittings at the shock, and at that canister in the middle of your frame. I'd say unscrew it at the canister then cut the rest. or...grab a bucket and man up and cut that sh%t!! :D Bwahahaha!! Really, it seems like a ton at first but it really isn't a lot that comes out. Wrap a rag around it, cut, let it drip into a bucket. ;)
Just pull it all and trash it. Remove the shocks and everything in between and put in new shocks.
Might try bucket with rag method
Its just we have a brand new 5k driveway and my dad would kill me
Disconnect at the union that is about a foot away from the shocks. That is the safe way and you will only get a drop or 2. Then just remove the rest of the stuff without cutting the lines. If you had read about how to do it there are pictures in about everyone of those threads showing the union.
use the street
should use toyo dealerships driveway
yea i have seen the write ups
and like i stated earlier....those unions are so not readily accessible on my vechile
cant wait to this shit is gone
Ambrose67
