YAW calibration didn't work!!
kk4rosie1
I've been getting the trac control lights coming on at the slight turns and uphills. I've got a 3" lift on my 2001 4runner. It's been fine for years but now its constant. I do have some droop in the rear from coil sag but nothing too major. I was going to do the Andy Mod so I can disable the controls completely, but I figured i'd try to calibrate the yaw sensor first. I did all the normals, checked my tire pressure, level ground, etc before I did the zeroing and the lights came on and the sequence went as it should for the calibration... BUT I am still getting the light coming on at turns and some bumps. and losing power and ABS coming on sometimes. It's getting very frustrating. Any suggestions would be appreciated.
If i just unplug the connector from below the master cylnder will that just disable the ABS, VSC and trac control? at this point that is fine until i have time to perform the andy mod
brendaglores
