Yes another 2021 LED headlight question!
amir_gh
Hello everyone,
I know that there are many posts about this already. There is also one that is 30 pages long! I read all of those! :-D I just want to make sure before order these.
I have a 2016 limited. I would like to know if I can just buy none limited 2021 LED headlights part number ( 81070-35600 ) (81140-35610) and swap the connectors. I understand the DRL and high beams wont work right if I go to Bi-LED OEM that comes with limited and TRD Pro. I have two questions:
1- Will my DRL and high beam work as designed if get the regular (none limited) OEM Led headlights?
2- I am planning to swap the halogen high beam bulb and use xenon depot DRL harness on OEM 2021 headlights to match low beam color . Will this setup work?
not 100% sure if the 2021 are low led and high halogen (non pro / non limited models) , someone on here mentioned that 21 is led low/high for all models. If thats the case you would need the 2020.
In my 17 SR5 prem. I think I have the 2020 headlights non pro/limited, with the led low and halogen high. It was a simple pin connection swap and everything works as it should. As for swapping the halogen bulbs out yes it ll work
You're correct. I meant to write 2020. Where did you get yours? Can I get the part number?
picked them up off a forum member here. I'd recommend checking secondary market for them. I've seen a few pairs from $250-350 range (FB market, offer up etc.) As for the part number not sure of that but from the dealer I think it was $900-1000 for a pair during sales.
I should have bought the OEM at first.
seltzernator
