Yes, another lift question....
Tenn_volsfan56
I have ordered new front quick strut assemblies and plan on installing them next week. I read the "Lift Sticky" but I need some input on what I should get. I can't afford to hit and miss so I gotta try to get it right the first time.
My Runner rides pretty level because of the booster blocks I have in the rear coils but I am replacing the coils next week also. I want it to ride a little higher up front when everything is installed. I think spacers are what I need. Not sure what size.
Any help is appreciated. Thanks,
if you just want to lift the front a bit a small spacer will do that.
If you don't want to play a guessing game, I would put the new fronts in along with the new rears and see where it sits. Then you can accurately tell how much you need to change the front to get your desired results.
That sounds like what I'm gonna end up doing. Thanks for the replies guys. I appreciate the input. I've never replaced struts, coils, or wheel bearings so it should make for a fun week of learning.
charlesz
