Yokohama Avs S/t 285/60 R17??
tango44
Hello everyone I just want to know if this tires are ok on my 2007 V6 Limited I just bought it and it comes with this ones.
What tire pressure should I be using on this ones?
Tango44
Tango...
I spoke with tire rack about running these same tires and they recommended against it....look into the Bridgestone Dueler H/P sport in a 275/60/17.
I forget the reasoning, i think it was because of the width/height ratio...its just too short and throws off things just a bit too much.
the Dueler H/P Sport in the 275/60 is a great option though..im currently runing Toyo Proxes S/T and like them as well (they are all season rated....but anything more than a dusting of snow and they are out of action) but wanted something a bit more sporting.
Tango44
285/60/17?
I'd be interested in seeing a pic. do you have aftermarket wheels with a different offset?
Since the diameter of the wheel is nearly the same as a stock 265/65/17 the only concern is the width. Some 285 tires need a minimum wheel width of 8". Stock is 7.5"
Are you experiencing any rubbing when making a sharp corner?
Re: Re: Yokohama Avs S/t 285/60 R17??
rook said:
285/60/17?
I will post pictures tonight and no I dont have any aftermarket parts on it, just the tires, and I dont have any problem making sharp corners.
Thanks.
