Yota lean- is it ever to late?
So I’ve had my 07 lifted with 5100’s all around, 884’s up front and superflex in rear and camburg uca’s for about a few years now. Resulted in a 3/2. Sitting on 275/70 ko2’s. And now I can see that its leaning left. (Drove behind my wife while she was driving it). Also handles like it’s tilited a smidge to the left. Is it ever too late to add spacers to correct it? Any pro/cons trying to fix it after having the lift that long?
Lean
I'm interested to hear some responses as well. I have a 3/2 lift and ended up with pretty bad lean as well. My big gas tank skid doesn't help. I ended up going with the 700lb springs up front. I have no preload on the passenger side and about .75" preload on the driver's side if I remember correctly. I purchased an OME spacer from Toytec to help balance out the rear in hopes of lowering driver's side front preload as I can feel a difference in the way the front suspension handles from side to side due to the preload difference. I'm also thinking of switching out my springs as I've heard the Icons tend to sag more than others, not to mention it seems other springs are side dependant in the rear which might help reduce or eliminate the need for a trim spacer on that side.
Deka
