zacattack20's Matte Blue ‘98 to '02 Sport Edition - Not the normal build thread
DRL Switchbacks
DRL Switchbacks
After numerous variations and products, finally got these sons of b****es how I want them (for the most part). I wanted them to be sequential but I’m happy with them like this.
The old strips I had were horrible, I hated the yellowish color of the white, the blinkers didn’t work properly, and the LED’s in the strip kept going out. So I had to kind of make these myself.
With the previous attempts at this, I had removed the blinker housings and backed the opening with the same mesh of the grille and lower grille. Cut out holes for the LED tracks and slid them through the holes and created brackets in the back that attach to existing bumper screws.
Used LED tracks with a frosted lens, with Vvivid tint on top. I like the look of the lights better without the tint but don’t like the white lens when off so the tint had to stay.
Used some COB LED strips from eBay, one white and one amber strip in each track, and then used a switchback module from Oznium to control them.
<br><br><br><br>
The white is controlled by a relay connected to the parking brake so when it’s up, the lights are off, and then on when the parking brake is put down.
<br><br>
Addco Sway Bars
These Addco sway bars are single handily one of the greatest things that I have ever added. They greatly improve handling even being lifted and can take turns much faster. I had them previously but sold them off with everything else years ago. I forgot how much better they make the truck handle.
They are still safe on my 4Runner... :bowl:
I run the rear all the time and disconnect the front when going offroad...
-Charlie
Been working on these corner lights for some time now. Over the years I have attempted a few variations of something like this but never been satisfied. I have never been successful at opening up these corner lights and having them go back together and look good. Or had any luck with any of the LED ideas I’ve used.
Using the JDM clear corners to not have the ugly reflector in the way of what I wanted, I did all of this without having to open up the lights. The corner lights are easy to black out without opening them, just soak the lights in some Super Clean degreaser for a few minutes, shake and wash out.
The strips I designed the exact same way as my lower bumper blinkers. Wired a white and an amber COB led strip to a switchback module from Oznium and then using some recessed LED strip tracks with diffusers that I tinted as to not be so obnoxiously white when turned off. I was able to cut out the holes for the tracks from the back of the corner light and slide in the tracks and clamp them in from the back.
I still wanted a normal LED bulb to go in the socket position for forward facing light. I wanted a bulb that looked good design wise where you didn’t just see a circuit board of an LED. There are no simple 194 switchback bulbs, so I found these 7443 switchback bulbs from The Retrofit Source
The 7443 is the same size as the lower bumper blinkers. So since I wasn’t using the normal housings from the bumper blinkers, I cut out the socket mount and fiberglassed it to the back of the corner lights.
The white strips come on in the parking light position and the white bulb comes on with the headlights. The amber strips just work all the time as the blinker.
So much blinkage…..
<br><br>
<br><br>
<br><br>
<br><br>
[MENTION=69310]zacattack20[/MENTION]
did you put two bulbs in the side of those side markers in addition to the normal bulb? interested to see how the bulbs plug into the back of those.
btw, what company re-did your gauge cluster (speedometer)?
They aren’t bulbs, they are led strips. I cut out slots out of the back of the corner, and then put some led tracks with led strips. So just wires coming out that I combined into a separate waterproof connector.
The gauge faces were done by Black Cat Custom
hey
always cool build and maybe something interesting for you? I also have a 96-08 dash so the older upside down back window control. I relocated mine to the dash when doing the 99+ center console update. having it upside down is not a huge deal but I did consider doing a custom switch to correct the upside down lettering.
84810-35030 is ours
8481035020 is a 1996-08 Hilux Surf
I can find them in Russia... I might try it...
<a href="https://imgur.com/AwqHThn"><img src="https://i.imgur.com/AwqHThnl.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/he9eGUI"><img src="https://i.imgur.com/he9eGUIl.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/JId92Q7"><img src="https://i.imgur.com/JId92Q7l.jpg" title="source: imgur.com" /></a>
84810-35030 is ours
Those do look cool. Would depend on price.
I just popped off the BACK WINDOW face lettering and flipped it around and then rubbed off the up/down lettering. It works good enough for me.
oh man, I hate to see this happen to one of the better builds on this site. Maybe you can buy some junk 4runner off copart and swap your stuff into it? that might be a decent option for you. Best of luck! We're all rooting for you.
The blue 4Runner was totaled in a brutal freeway off ramp rollover accident but the driver was relatively OK, luckily.
We saw the results on his IG page @98trd4r
Ooooooohhhhh... That's why I didn't know what was going on. Thanks for the explanation. That sucks about his 4Runner, but it's easier to replace than a life. Get well soon zacattack20 and sorry for your loss
Philthyphilthy
