rigtec
Hey team!
Last Sept, I decided to add an 8 inch LED to my bull-bar mainly for the aesthetic aspect of it. When I did that some mistakes were made that cost me plenty but I also learned a valuable lesson. During the illuminated switch (from AOB) installation/wiring portion, I allowed my 12V interior lighting feed to cross over to the 'Dimmer dial (rheostat)' Gnd circuit. This was because I was unsure of the new switch wiring color code; it's different on the "slee off-road" brand. Though it was only for a split second and didn't even blow the courtesy circuit fuse, it was all it took to cause major problems. A few days later, I was seeing the 'ABS' light come on 'momentarily', and then go out.
Next it was the '4low' lamp doing the same thing. Eventually almost ALL of the different (unrelated) warning system lights were showing up (intermittently), including the airbag, steering, skid, TRAC, compass, econo... etc. So I spent a substantial amount of time with the electrical systems manual learning where all of those warning system signals were coming from. It turned out to be my 'Main body ECU'; which manages the interior lighting system, dashboard courtesy lamps and instrument cluster.
FST FWD: ...Since then, I've had a number of 'Hands-on' forum members (very capable guys) P.M. me, requesting assistance with dash lights that went out during an illuminated switch install, but failed to come back on; there were a lot us that participated in the A.O.B. Group buy several months back ("Not saying that this had anything to do with the A.O.B switches themselves"). My point: If you happen to be doing a 'Factory style switch' install and you're going to use the inst cluster circuit to feed the illuminated LED icon on the face of your new switch, 'DO NOT' allow the 12V (HOT) to go ANYWHERE NEAR the "Dimmer dial" ground side; that circuit goes directly to the "Instrument cluster & main body ECU!
PS: If by chance you are already having trouble w/ your courtesy lighting 'dimmer circuit' or you're getting False system warnings; which aren't stored as DTC logs, and think the trouble may be 'MB ECU' or instrument cluster related, here are those part numbers/prices (2010-2015):
'Main Body ECU' (aka-Multiplex Body compu)#89220-35021 $476.00
'Instrument Clust.'(2010-2013... '14 and '15 speedos are different) Toyota 4Runn #83800-35N01-RP $900.00
"These prices are from Toyota dealerships that sell on EBAY so shop around; you could pay as much as double these prices if you buy locally!" Rgds
