Eibach Pro-truck lift
That’s awesome.
It was good meeting you at toytec’s appreciation day. I am glad Eibach was able to make it out to Denver and it was awesome you guys donated a kit for the raffle. What a blast that day was.
When you get a chance, could you post the coil spring rate for the kit?
There will be choices from 200lbs up to 500lbs.
Just finished reading all 39 pages. I've pretty much decided to go with this kit. I'm debating doing it myself. Would need to buy floor jacks, jack stands, torque wrench, etc. All of which I need...
My attached garage it getting tight and I really need to build a barn before adding more large items to the garage...
Questions to the gang:
What did you spend for install (labor) at a shop?
How much $ for Alignment?
I paid $700 for install and alignment by a reputable shop known for lifts in the Jeep world. It's a fair price for my area. And it's local to me which is even better.
I paid $675 for install, alignment and mounting/balancing new tires.
I also ended up paying them to push in the fender liner... (which i still don't think was necessary)
Damn that's a great price for install+alignment, If I was closer I'd buy the kit today!
Hey [MENTION=318203]Ryan at Eibach[/MENTION], I'm considering the pro truck lift kit but am planning on getting a 200+lb rear bumper in the near future. I know you mentioned having adjustable rears in the future but I think I would have my rear bumper before that happens. Does Eibach make a rear spring for the 2010+ 4runners for addtional weight? If not, is there a spring you would recommend that works with your rear shocks? Thanks!
Our rear spring gets 1" unloaded. You may want to look at the springs we manufacturer for Toytec and Wheelers. I believe there's a 1.5 and 2.0" option. With your bumper you'll probably end up .5 - .75" less.
Do it yourself.
It's pretty easy and you'll save a ton of money.
Go get a lifetime alignment and you're good to go.
What are the off-road capabilities and limitations of these spring/shock?
Hi Stephen,
That's tough to say. We have a hard time getting our Tacoma stuck anywhere and it does pretty well out in the desert when we're testing UTV's. It's pretty capable and rides great on the way home.
I sent the support rep of Suspension Connection another email this morning to confirm that the kit would be shipping out some time this week, and was told that Eibach informed them that the lift kits on backorder until 7/12. Not sure what I want to do anymore as they can’t guarantee that the orders will be fulfilled at that time, and Eibach has already pushed the backorder date twice...
Have you received your order yet? I can confirm it’s not happening this week either.
Your truck looks great! Geez, I really like those TRD wheels!
Thanks! Makes a huge difference. I have black lugs but forgot to bring them to the shop. I'm going to pull the wheels off to check the ligs on the spacers on Sunday amd will put the black lugs on then.
rear springs
If someone that bought the Kit and is thinking / wants to sell the rear springs to get a higher lift or heavy rated spring set, I'm looking for a rear set.
Thundro
