TOTAL CHAOS Upper Control Arms
TOTAL CHAOS suspension systems & accessories are 100% Made in the USA and handcrafted by our fantastic team in Corona, CA. TC’s experienced fabricators work very hard to provide top performing products that are built to last and also look great. The best companies in the industry provide components like bushings, uniballs, and hardware (all 100% Made in the USA). Each component is hand-picked and tested over thousands of miles to give you maximum performance and durability.
CLICK HERE to learn more about TOTAL CHAOS products and to check out our current offerings for your ride!
TOTAL CHAOS
WWW.CHAOSFAB.COM
: @mademan⁣925
Hope everyone is enjoying the holidays! We are grateful for our extended family of TC customers and the amazing companies that represent our brand across the globe. THANK YOU for a wonderful 2018.⁣
Did you get a set of TOTAL CHAOS Upper Control Arms under the Xmas tree?
If not, give one of our Authorized Dealers a shout to place an order!
Note: We'll be back in the shop 1/7 if you need anything directly. Give us a ring!
See YOU in the NEW YEAR!!!
TOTAL CHAOS
WWW.CHAOSFAB.COM
Tundra rocking TOTAL CHAOS UCA'S out doing some camping around the Holidays. Are you getting out for New Years? Post a pic or two of your adventures!
Happy New Year!
I have ext travel kings and at full droop im hitting the spring. What do you recommend I do for that?
TC FUN FACT⁣⁣
Not all things are created equal. ⁣⁣
- 1 1/4 x .120 4130 chromoly tubing.⁣⁣
- Custom machined uniball cups.⁣⁣
- Production stamp coded.⁣⁣
Did you know that all TOTAL CHAOS suspension components are part number stamped and production stamp coded?⁣⁣
UCA's are stamped on the pivot gussets. ⁣⁣
This information is very helpful to our tech support staff when they are helping customers that have purchased used TC equipment.⁣⁣
TOTAL CHAOS on Instagram: “TC FUN FACT⁣⁣ Not all things are created equal. ⁣⁣ ➖ 1 1/4 x .120 4130 chromoly tubing.⁣⁣ ➖ Custom machined uniball cups.⁣⁣ ➖ Production…”
Do you experience wandering or darting of the vehicle while driving? Are you running a lift kit?
TOTAL CHAOS Upper Control Arms are designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle's steering when 2.5"-3" lift kits are installed.
Click here to learn more about TC UCA's for your ride
What coil-overs are you running with your TOTAL CHAOS Upper Control Arms?
How about some ole workin' boy suspension :D
Old grubby yummy Fox 2.5's with new TC bling, fully stealth KDSS EXP LCA's ;):
...eeerr where we only supposed to post shiny new unused CO's :( Cus as much as i'd love a new set of kings I have put 40k of "hard" use on these, which is why there are new U&L's, they were gone...
That's a nice looking setup!
:frog:
seltzernator
