Poly sway bushings, nothing but headache !
maxspeed96ct
So its been almost a year since I first installed these. I have the poly around the two bar mounts and a set on each endlink.
And they wont stop squeeking ! even with just the slightest movement my car sounds like a old wheel barrel !
I tired greasing the crap out of them , squeek comes right back in a week or 2 .
I isolated them with teflon tape and that lasted about 1 month. And now the squeeking is back !!
Anyone else have this issue?
im ready to ditch the polly and go back to some oem rubber. :toilet3:
did you get the ones with a grease zerk? (i know the endlinks don't have zerks)
I've been quite impressed with my poly bushing, mine don't squeak. I have had them for about 10 months or so.
Also, I have the black graphite embedded ones with the grease zerk.
What grease are you using?
no zerk fittings on mine, wish there was.
You need to use synthetic grease with poly.
I tried marine grease, synthetic grease.. nothing seems to last once the grease works its way out....
I have polyurethane bushings for my steering rack and both sway bars.
My poly bushings used to squeak a lot, too. I used some copper anti-seize and it hasn't squeaked since.
The provided grease was washed out and gone in a few weeks.
maybe he is nearing the end of their lifespan?
his are older then mine, but mine still seem to be in good condition.
hhmmmm I have some never-seize in my garage , ill try that next..
I guess that will be my last attempt before going back to stock rubber.
Have you ever tried proper grease? I'd try poly grease first. Here is another link.
I am curious about your issue since I am about to order some new bushings.
polyurethane lube
Well I tried the grease that came with the kit, I thought that was the right one and only lasted a few weeks before making noise.
And ive tried several others aswell.
But ill look into the one in your link, I just think it will work its way out in a few weeks just like all the others.
I have the energy suspension red poly sway bar and end link bushings. My sway bar bushings are the greasable ones. I' ve never had a problem with mine squeaking every time I change my oil I give each one a shot of grease.
Thats the brand I havem just mine dont have any grease fittings...
