Timing belt/water pump kit or piece together?
Rocky5000100
I've got a contact who will do the install for me, but I still need the parts for the timing belt and water pump change for my 4Runner with 111k miles. I just bought it and can't find a sticker saying its been done anywhere, nor is it in the carfax.
Is buying a kit with all the pieces like this worth it price-wise?
http://www.ebay.com/itm/190521450224?
If not, what pieces exactly do I need to purchase? I failed at finding a full list anywhere.
Thanks!
If I was in the states I would have bought the first kit you posted. Since I have to pay duty and taxes I just took mine apart and got what I needed. I only changed the pump/t-stat and T belt. Everthing else was in great shape and didn't need replacing. But again I spent over 200 on just a pump and belt so for 300 to my door I would do it all.
I have done a lot of research recently because I need to change out my timing belt soon and this is the kit that I am going to go with:Toyota Timing Belt Water Pump Kit Genuine Parts 4 Runner Truck 3 4L V6 | eBay. I am going with this kit because it has all Toyota/OEM parts and the other kits that have been posted from ebay and amazon DO NOT use all Toyota/OEM parts. In my mind it is worth it to spend the extra $50-$100 for factory replacement parts but that is just my $0.02.
And to answer your question: Yes, buying everything in a kit will definitely be cheaper than trying to piece everything together.
The only difference between the first one he posted and the one you posted are the drive belts. Bando USA are just as good as Toyota brand ones, and I don't see the need to spend an extra $50 on the drive belts. That is unless I'm missing something.
There are a couple differences between the kit he posted and the kit I posted:
- 1 Timing Belt Mitsoboshi TB271M Vs. 1 Timing Belt Toyota 13568-69095/YZZ03
- 1 Front Crankshaft Seal KP/Stone/THO 90311-40022 Vs. 1 Front Crankshaft Seal Toyota 90311-40022
- 2 Front Camshaft Seals KP/Stone/THO 90311-38051 Vs. 2 Front Camshaft Seals Toyota 90311-38051
- 1 Thermostat (82°c) Kuzeh 90916-03075 Vs. 1 Thermostat (82°c) Toyota 90916-03075
- 1 Air Conditioning Belt Bando 4PK-0870 Vs. 1 Air Conditioning Belt Toyota 99364-20870
- 1 Alternator Belt Bando 4PK-1050 Vs. 1 Alternator Belt Toyota 90080-91090
- 1 Power Steering Belt Bando 4PK-1070 Vs. 1 Power Steering Belt Toyota 90080-91126
That's what I was looking at. I need to just replace my tensioner, since the Timing Belt was done about 40k ago but they didn't replace the tensioner, just the belt. I think I will go ahead and do it all just for the peace of mind. Of course that's only if lubing my tensioner doesn't work to eliminate my squeak.
Thanks for all the suggestions guys. I'll probably go for that one from amazon.
I don't mind if its not all OEM.
Water pump always AISIN (OEM manufacturer for toyota). if this is expensive, Paraut is another good water pump.... but don't go with GMB.
T-belt always TOYOTA
Crank and cam seals TOYOTA, if you use any thing else, they'll fail before 60 K miles
T-belt tensioner and idler bearing KOYO, NSK OR NACHI. NO GMB
You really SHOULD mind if it is not all OEM.
I installed a cheap non-OEM waterpump in the past. It has a lifetime warranty (yay!). It still FAILED at 40k miles use. I then paid labor and the cost of new OEM waterpump to have the job done right.
That lifetime warranty is near useless to most folks. Cheap parts manufactures offer it because they know most folks sell their car before 50k miles rolls around and the part fails.
Get real OEM parts or you will regret it down the road. Trust me. I've had my 4Runner for over 10 years now and can tell you that cheap non-OEM EBAY/AMAZON/AUTOZONE/MOOG ect parts will fail.
I prefer to buy Genuine OEM parts from here: Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
They are based out of AZ and sell real OEM for about 30% less than normal dealer $$. In fact their prices are often cheaper than NAPA and you get a real Toyota part.
:popcorn:
:popcorn:
Sorry, I should've been more clear. Certain items I do care about oem parts like the water pump and belt itself , but for things like brakes and pads I've found there are much better options with other brands (at least in my experience with my last two cars and motorcycle ). But those I guess are performance parts, not parts like a belt where you need a reliable part that just does the job.
I have Brembo performance rotors and aftermarket performance pads with my stock calipers. So yeah I'm not 100% OEM either.
Just stay away from the cheap ebay/Amazon stuff is my point.
The aircabinman kit with all oem parts and a Toyota belt is the one you want to get. not the one you posted(that seller has full oem kits and non-oem kits. verify before you buy).
I have installed that kit on both of my 98 4runners.
Really how you should be looking at this is not that it may cost $50-100 more.
It's that it takes 10 hours and a sore back to change all that stuff and you don't want to do it any more frequently than you have to...
a squeaky idler pulley after 10k miles will REALLY piss you off...
You mean this one :thumb3:
A couple links on here and in the other thread have huge price difference from 25-100 dollars. And they all say OE toyota parts
4ever4r
I think I may go with that kit
This is what you want. Shame you didn't buy it 6 months ago, use to be $303. And a few months before that it was $288.
Bummer, hopefully I can buy it before the price goes up again...
4ever4r
I'm sure you won't be disappointed.
I have that kit on my watch list. Just waiting for the $$$$$.
That makes 2 of us. I'm hoping I can find another member on here who can help me get everything installed.
[edited]
There is the question of whether or not those are even real Toyota parts.
I can buy a Tiffany's necklace on EBAY or Amazon but it doesn't mean that a real Tiffany's piece will show up in the mail. There are lots of fakes on EBAY and Amazon and you have no way to prove it. BUT they do have 99.9% positive feedback and I would seriously consider this kit if I was doing it myself. I buy "grey market" Alpine from EBAY power sellers and have had 0 problems with quality.
And it does seem like a heck of a deal. $355 for the EBAY "Toyota" parts vs $450 for Camelback Toyota Online. You may want to try and call Camelback Toyota to see if they will match this kit price. I bet they would come within $50 of the price.
2001ATL
