LED turn signal "hyper flash" fix?
murderface
OK... got some LEDs for the front end and the turn signals are doing the "hyper flash" as if a bulb were burnt out... I read I will need to put load resistors behind the bulb, not sure which one I need though
You may be able to fix it with a new turn signal relay. On my 99 all I did was grab the 6 dollar relay off the shelf at the parts store, fixed. I can't remember the number off hand but it was a basic flasher relay.
If you still have questions look up Low Range Ofrroad. They are a great company who specializes in everything Toyota. They carry all the parts to resolve this issue and have done it for many people.
Hope this is the right one
I can eyeball that EP-33 and tell you it won't fit. Get the EP-35.(unless they changed between my year and yours.)
curious... does anyone know if there is a true white led bulb? i thought i had white bulbs but next to the headlight its definitely has a blue color to it
AndiGarage
