Old 08-16-2014, 01:40 PM #1
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 will become famous soon enough
Robb235's Avatar
Real Name: Robert
What is the stock MAF tube diameter?
My '99 5vzfe has the type of MAF sensor that bolts into the pipe (instead of the housing and pipe being all one assembly like on the '96-'98 models).
What is the inside diameter of the MAF tube? I tried to measure it with my dial calipers, but at one end of the pipe, the opening is larger, and transitions to a slightly smaller diameter closer to the MAF. My dial calipers couldn't reach down the pipe far enough to measure the smaller diameter.
I'm thinking the diameter is anywhere between 2 5/8" and 2 7/8". Does anyone know exactly what it is?
1999 Toyota 4Runner Limited 4x4 - Turbocharged GTX3071 - uaEFI Standalone ECU - DW255 fuel pump - 550cc fuel injectors - Rear Elocker Retrofit w/ 4.30 gears - 2wd Low (2Lo) On Demand - 231mm Tundra Brake Upgrade - Hayden 699 Transmission Cooler - Monitoring ATF Temps w/ My iPhone - DIY Projector Headlight Retrofit - Backup Camera Retrofit - 265/75/R16 Cooper Discoverer AT3 - OME 906 Rear Coils
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 08-17-2014, 11:39 AM #2
DocW8494's Avatar
DocW8494 DocW8494 is offline
DocW8494 is on a distinguished road
DocW8494's Avatar
Not sure why you ask, but my best guess is the o-ring is a piece of crap right now and needs to be replaced. I just replaced mine, but I went to the parts store and they took one off the shelf to find the right size for me.
I don't know the size, but offering a way to find out easily at the parts store. Good luck.
Dave
SHEBA - My 1999 4R, 3.4L, Manual, 4WD, 2.5" EMU suspension.
BEST truck ever!!!!!!
DocW8494 is offline   Reply With QuoteReply With Quote
Old 08-17-2014, 01:39 PM #3
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Dave
Huh? What o-ring? I'm not sure I understand what you're saying. If I go to the parts store and ask for a MAF sensor, they'll just hand me the sensor piece that drops into the tube. I'm wanting to know what the diameter of that tube is.
Old 08-17-2014, 08:40 PM #4
DocW8494's Avatar
DocW8494's Avatar
I'm thinking I got a different setup or something. Anyways, the MAF I have is right behind the cruise control right after the air filter assembly. Held by 2 screws. O-ring but is a whole assembly all together.
I'm not sure of the diameter for the tube.
Old 08-17-2014, 09:13 PM #5
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all
TheDurk's Avatar
Also, that assembly includes TWO sensors: The MAF (two wires inside small tube) and the Intake AirTemp sensor (bulb on outside of tube). If you are trying to build your own MAF sensor assembly, I applaud your initiative but I think it is more effort than it is worth. Rockauto sells off-brand sensors for like $50. Has to be better than a homebuilt.
My Backyard Frame Swap
Old 08-18-2014, 06:06 AM #6
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Lol, I'm not building my own sensor. Do people actually do that? And yeah, I know the IAT is integrated into the unit.
I'm going to give CX's turbo manifolds and downpipe a go, and I need to build my own intake from the turbo to the throttle body. I need to maintain the same MAF tube diameter so to not throw the ECU off. Build thread to come soon.
Old 08-18-2014, 01:42 PM #7
TheDurk's Avatar
TheDurk's Avatar
Ahhh, it would be better to explain what you are up to. We get as many nitwits as geniuses on here. Sorry, I don't have that dimension for you.
Stock Exhaust Diameter Verruckt32 4th Gen T4Rs 4 09-13-2012 10:50 AM
Stock exhaust diameter? collin 3rd gen T4Rs 6 08-02-2010 02:04 AM
98 4Runner V6 stock exhaust diameter? monsterman 3rd gen T4Rs 1 04-21-2010 05:43 PM
stock exhaust pipe diameter countryhunner 4th Gen T4Rs 0 12-25-2008 11:01 PM
Stock Exhaust Tip diameter... beirish Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-12-2007 10:38 AM
