Which perch on 5100s for 881s (I searched!)
KurtL
So i will be installing 890s with billstein 5100s in the rear of my 2000 limited 4x4 weekend to replace the spacer lift i am currently using. When i get around to replacing the front I was planning to install OME 881s with Tundra 5100s. Which perch should i use to get a level stance, 2nd or 3rd and/or should i re-use the 1" top plate spacer i currently have installed up front?
Thanks!
