Old 07-22-2020, 11:51 AM #31
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute
JZiggy's Avatar
Also, where is that P7 connector?
JZiggy is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 11:52 AM #32
pavelvoivoda's Avatar
pavelvoivoda pavelvoivoda is offline
pavelvoivoda will become famous soon enough
Originally Posted by JZiggy View Post
Wondering if maybe I should just wire in a 10A or 15A fuse with this switch just in case.
yep, I think this will handle it. You can put a fuse but don't go above 30amps. I think you shouldn't have problem!
Let me know how it works
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
2person xUN diesel T4R equipped for long distance touring w/ light-duty off-roading. 1000kms range w/ subtank
Check out my FB page Toyota 4Runner Bulgaria
pavelvoivoda is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 11:55 AM #33
I think you can see it here it is on the lower part of the second picture...98 - 02 TOYOTA 4RUNNER LIMITED FRONT LEFT SIDE MASTER POWER WINDOW SWITCH BLACK | eBay
Power window  modification-s-l1600qweqrrwe-jpg  Power window  modification-s-l1600qweqrwqtwgdg-jpg
Old 07-22-2020, 12:23 PM #34
JZiggy's Avatar
JZiggy's Avatar
Thanks Pavel! I see that these wires leave the fuse block thingy via connector 1C. Since I want to wire the switch near the clutch start cancel button I'll try to tap into them there.
Old 07-22-2020, 03:43 PM #35
Cool, take a pic once you finish. I might end up doing the same after i install... power windows in mine!
Old 07-24-2020, 09:23 PM #36
JZiggy's Avatar
JZiggy's Avatar
@TheDurk @pavelvoivoda
Success! I wired in my switch as per Pavel's idea. Pretty easy to get to the wires once the fuse block was pulled out.
I tried a 5A fuse and it worked when running a single window but blew when running two. So I upped it to a 10A which was happy with 2 windows at a time.
Thanks again for the advice and ideas, guys!
Old 07-25-2020, 11:12 AM #37
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all
TheDurk's Avatar
Yeah, that'll work. Sunroof should be live, too.
My Backyard Frame Swap
Old 07-25-2020, 12:21 PM #38
JZiggy's Avatar
JZiggy's Avatar
Don’t know for sure, don’t have one.
Old 07-26-2020, 05:48 AM #39
Since I drive a manual, I found the center dash board switches above the ac/heater controls in a junkyard and replaced the original and used the ECT button to make the same type of switch but it turns on all the accessories, without the key in the ignition. It's nice to turn on the radio or charge something for a few minutes, but it will drain the battery if forgotten.
Power window  modification-ect-switch-jpg
I suggest if you want to prevent battery depletion from forgetting manual override switches like these ones ON, use a small circuit board that breaks the circuit once the voltage drops below a preset one, that you can set yourself with a small potentiometer on the board. They are available on ebay and are a few bucks and they themselves use very little current, like an alarm LED.
https://www.ebay.com/sch/i.html?_fro...utoff&_sacat=0
Power window  modification-image_881446-jpg
Power window  modification-ect-switch-jpg  Power window  modification-image_881446-jpg
Rear Window Power in Accessory Power WeAreSLO 3rd gen T4Rs 1 04-29-2015 03:29 PM
Rear power window/ Power locks Brian Keeler 3rd gen T4Rs 2 06-01-2010 02:21 PM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
Center Con Power Modification anyone? pbenson1167 4th Gen T4Rs 6 12-26-2008 08:07 AM
'93 power antenna modification unibody Classic T4Rs 1 06-12-2006 04:17 PM
