phattyduck
Finally pulled the trigger on the rear window interior switch mod. I followed inspiration from this thread and followed [MENTION=91393]papabeach[/MENTION] great idea to just tap into the wiring at the ECU rather than back in the guts of the door.
I opted for a 1st gen 4Runner window switch because 1) I had an extra 2) it's small and 3) still OEM
Rear outboard shock mount adjustment fun times!
Shock is now in a happier location with clearance from the frame and the tire.
Extension and compression (I didn't try too hard to get the tire stuffed all the way up to bumpstop contact but it's close enough to confirm it's where I want)
No tire touchie! Huzzah!
JZiggy,
How far is the center of the new hole from the edge of mount?
Thanks!
