Recurring Axle Seal Leak
After I did both of mine, the passenger side had started leaking again (service records show it was replaced twice by a dealership). I used new retainers (don't remember if I flipped them), applied FIPG around the axle before I pressed the inboard retainer on, and also applied it around the axle housing before I installed the seal. Made sure to clean off any excess. Have put ~20k miles on it since, over 10k of those miles were from Seattle to Cabo, twice. Lots of hard miles
I flipped the retainer many years ago on both axles and have around 150k using this method and no leaks. Didn't use rtv, so can't comment on that. If I had to do it again, I would still flip the retainer using Toyota seals. Good luck
MikeM
Sounds good. Thanks for the input. Now I just need to see if my 12 ton harbor freight is up to the task.
I flipped retainers (and used new ones) and used the updated seals. No FIPG and I've got about 9k and 10k miles I think on the job (was slow getting both sides done). Done a lot of offroading on them. Just pulled the ABS sensors not long ago and everything is still bone dry in there. Pretty sure I was the first one to change to seals too, everything seemed to likely be original (old style seal and OEM bearings with very faded grease seals). I wonder if things get screwed up on this job in the past if it just basically hoses the axles unless you do the FIPG.
I saw on a different thread that you bought the bearing from napa. I was looking on there and couldnt seem to find one fir the wheel bearing, do you have a part number or a link to the one you bought?
I had mine replaced at a shop, first time it leaked, second time after getting "fixed" it leaked. I was told there was a groove worn in the shaft but have not looked any further into it yet.
Planned to swap a locked rear in but considering selling now. 2020 TRD tacoma looks pretty good and I bet the seals don't leak!
Here's the part numbers I have for rear axle seals:
Rear wheel bearing 90363-40020-77 or Nachi 6308-2NSE (96-00) / 90363-40068 or NSK 40BW06CG50 (01-02)
Rear axle retainer 42423-20010 (2 per side)
Snap ring 90520-36045
Outer seal 90313-48001 (96-00) or 90313-54001 (01-02)
Inner seal 90310-50006
O Ring 90301-88077
O Ring 90301-88077
Is it safe to assume the only difference in abs and non-abs axles is the abs uses two retainer instead of one for non-abs? I'm looking at this kit and the non-abs only has one retainer in it. I was hoping I could reuse one of the retainers closest to the bearing and use a new retainer on the seal side. Looking to replace the bearing and retainer plus a new factory seal. I cant imagine the retainers are different for non-abs vs abs. Mine is an abs axle.
Wheel Bearing- Toyota Truck, 4runner, T100 & Tacoma Rear Wheel Bearing w/o ABS (1975-2000) 936
I think the retainers are the same for ABS and non ABS.
O Ring 90301-88077
Thanks for these part numbers
I was able to get the Nachi 6308-2NSE bearing for $26 free shipping at
6308-2NSE9 NACHI bearing 6308-2NSE seals 6308-2RS bearings 6308 RS Japan 6308-2NSE Nachi bearings [6308-2NSE9] - $26.00 : JSB Great Bearings, online radial, pillow block and miniature bearings store
Seemed of same quality as stock and stamped made in Japan. Bought retainer on ebay for $16 and my local dealership had the seal for under $7. Not too bad for doing a bearing replacement. Now cross the fingers it doesn't leak again
Did you check that the rear diff breather was clear? A clogged breather will cause rear axle seals to leak faster than Sonic the Hedgehog can run. And that's fast!
Good luck!
Pat☺
Good luck!
Pat☺
Yeah I've actually modified mine and all is clear. Good advice though. My seal was riding on bevel part on the retainer. I flipped the retainer and used FIPG on the retainer and seal. Did the sharpe test and mine isnt exactly riding in the middle of the retainer but I think it will be enough which kinda surprised me since I went 5mm from the shiny part of the axle.
Hopefully this fixes it for good.
