Tundra TRD coils to OME 883. Strut perch setting?
DDeezenuts
I have searched and searched but can not find the answer to my question. I currently have Tundra 5100 bilstein shocks and Tundra TRD coils up front. Front has settled with plate bumper and winch. Was thinking of swapping to OME 883 coils due to additional weight. Would I have to lower the perch setting on the struts to compensate for the 883? I do not remember where they are set now. I think in the middle somewhere… Would like to be in the 2.5” lift range
Those that are running tundra Bilsteins and 883s… what perch setting are you running? Thanks…
You should be on the 3rd perch with the TRD Tundra coils. That's the recommendation when running a plate bumper and winch. If you don't remember where they are set, you should check first. IMHO.
Thanks but I am not asking what perch for tundra 5100 and tundra trd coils. I’m pretty sure I’m in the middle now and they have sagged under the weight of the bumper and winch. I don’t want to set the perch higher.
Regardless of my current set up, I’m asking for those that have the tundra 5100s and OME 883 coils, what perch do you have them set to? I found minimal info today that suggests lowest perch but can’t say for certain if it’s the lowest perch on the tundra 5100s or 4runner 5100s.
Im basically in the same boat im installing my first lift and decided to go with ome 883s and 5100s. i found a yt video talking about not going past the 2nd perch im going to try that
