Old 01-14-2010, 02:22 AM #16
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Originally Posted by juiceboxer View Post
Approx. 1" difference. google tire size calculator and you can compare two different tire sizes against each other.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 10:11 AM #17
ryani ryani is offline
ryani is on a distinguished road
The way I painted them was quite simple. Bought two cans of Duplicolor Charcoal Metallic a can of clear and some red scotch brite pads.
1. Prep Prep Prep- I degreased with rim cleaner and then simple green. Then scuffed them up with the red scotch brite pads. It takes awhile but the result is worth it. After that cleaned with water and then brake cleaner to get everything off.
2. Got them up to room temp and blew them off with air then painted them with about 4 coats with about 7-10 min apart. I let that set up for about 15 min and then put about 3 light coats of clear on.
Then I let them sit in the heated garage at work for about 2 weeks to set up.
I got them on and no chips on the rims
I would say prep would be the most important.
Have any questions feel free to ask
ryani is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 03:07 PM #18
FoneRunner's Avatar
FoneRunner FoneRunner is offline
FoneRunner is on a distinguished road
FoneRunner's Avatar
I have a question...hoiw much to ship those wheels to me and do you take paypal? ok, that's two questions....feel free to answer them in one reply though...
'98 4Runner Limited Desert Dune 4WD lifted, locked, TJM'd, OME'd, LC'd, LED'd, ACC'd, CB'd, Gobi, Hilux'd, JDM'd, etc...
'98 Tacoma SR5 slightly built, '15 4Runner TEP
FoneRunner is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 05:11 PM #19
haha! How about this. You can buy my old factory rims and you can try out your painting skills. Ha ha. Yes I'm very happy how the wheels turned out.
Old 01-14-2010, 05:14 PM #20
FoneRunner's Avatar
FoneRunner's Avatar
I guess that was my way of saying I'm very happy with how they turned out as well! Good job...one day I'll find a set of LC wheels...
Old 01-14-2010, 05:15 PM #21
theizzardking's Avatar
theizzardking theizzardking is offline
theizzardking will become famous soon enough
i want a set of these i'm trying to find them cheaper than that though.
Login : Toyota FJ Cruiser Parts and Accessories Store.
theizzardking is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 06:44 PM #22
I know thanks for the compliment. I can always keep an eye out around here for a set for you.
Old 01-14-2010, 06:48 PM #23
FoneRunner's Avatar
FoneRunner's Avatar
Yes, please...
Old 01-14-2010, 07:34 PM #24
LINY4Runner's Avatar
LINY4Runner LINY4Runner is offline
Real Name: Bryan
LINY4Runner will become famous soon enough
Real Name: Bryan
Originally Posted by t4r4life View Post
is there a website that shows whats the biggest tire u can fit on ur runner without any rubbing?
you're on it.
stock, don't go bigger than 265/75 (31")
lifted...well, it depends on how tall
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
LINY4Runner is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 08:01 PM #25
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
Originally Posted by liny4runner View Post
you're on it.
Stock, don't go bigger than 265/75 (31")
235/85 > 265/75
JohnsD90 is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 08:27 PM #26
Real Name: Bryan
Real Name: Bryan
Originally Posted by JohnsD90 View Post
235/85 > 265/75
pfft
yeah and that's why we air down...because we want less traction
ass.
Old 01-14-2010, 08:49 PM #27
JohnsD90's Avatar
JohnsD90's Avatar
Originally Posted by LINY4Runner View Post
pfft
i'm an ass.
You can air down a skinny tire to make it wide, but you can't make a wide tire skinny from filling it with air. And skinny tires are superior in most offroad applications.
Old 01-14-2010, 09:29 PM #28
96Blacklimited's Avatar
96Blacklimited 96Blacklimited is offline
96Blacklimited is on a distinguished road
just one Question. i doing my wheels black. I already did my prep. (really good) So i wanted to know if i can use Duplicolor engine enamel if i gonna use oven to bake @ 100 degrees for about 1hr in order too cure. What about VHT capiler paint (900 degrees heat rest.) can i use that too?
96Blacklimited is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 10:15 PM #29
KellyJ's Avatar
KellyJ KellyJ is offline
KellyJ is on a distinguished road
KellyJ's Avatar
How are skinny tires superior in offroad conditions? And also, the benefit of starting out with a wider tire before airing down is simply that the tire is wider already. No need to air down (as much) as you would have to do with a "skinny" tire. Airing down too much increases the chance of sloppy handing as well as promotes premature tread wear along with exposing more sidewall to sharp objects
'02 Limited 4WD
Stuff:OME 3"|ARB Tacoma|Light Racing UCA's|Savage KO sliders|285/75 Terra Grapplers|TRD catback|TRD wires|Brembo'd|VVME 4300K HID|LightForce 170|Exterior LEDs||Inside: Infinity Comps/Kicker/Nuvi625WT|Uniden 520XL|15% tint|Full LED swap|Backup camera
Pending Install:LC80 wheels,OME 883 and LC 8 wraps,panhard drop
KellyJ is offline   Reply With QuoteReply With Quote
Old 01-14-2010, 10:17 PM #30
Real Name: Bryan
Real Name: Bryan
I disagree.
But don't muddy up this thread, do it here;
http://www.toyota-4runner.org/polls/...nny-tires.html
