Guess what came today?
MillerPKA
P2160427.jpg~original
haha those are the guts of the headlight. The lens is really clear I'm finishing wiring right now, sometimes the poor Chinese translations are confusing but I'm getting there. Should have night pics in a little but I can't do too much else because the interior is gutted at the moment.
P2160428.jpg~original
P2160430.jpg~original
Yeah they will technically but you won't get near the results you'd like with the frosted lens, you can buy ebay replacements as long as the seal is good because these reflect internally and do not rely on the housing itself. almost done wiring about to go mount them all up should take about 30 min
Well I must have done something wrong with the wiring but its way too cold to find out whats wrong, the halos work but its freezing so no pics, just bummed I didn't get em running yet. I'm sure I'll get it tomorrow
What a coincidence I got my g3's today too
I screwed up the bracket on the right side so I have to figure out a more permanent way to mount the light but here is a teaser pic
utf-8BSU1HMDAwMjItMjAxMDAyMTYtMjAzO.jpg~original
Wow everything came in pretty quickly. How did my write up workout so far. I have to get ready for work, but if you haven't go it by tonight I will help you out. Just make sure each side goes like this. Power wire with fuse holder straight to the battery, ground gets grounded on the body, two black and yellow connectors from projector get connected to the ballast, cylinder like connector from the projector goes the same connector from the harness, H4 plus from harness gets plugged into stock headlight plug. I'll check back after work.
I'll be working on this around 11 for a couple hours in between classes I'll let you know what I find, I thought I did everything right the plugs were simple, but I was working on my car for 6 hours before I even started these so I could have just been a little loopy.
I've been trying a side at a time.....do they both have to be fully plugged in for them to work?
I think the reason its not working is I blew a fuse yesterday cleaning the interior out, wires touch and I'll figure out exactly has been messed up here pretty soon.
No cutting or drilling. I got a white halo but you can get blue red and green as well.
Help me out here. Last night I could only get the halos to work. Went out there this morning and neither halo or hid worked. Turned the corner lights on and nothing, checked the fuses, everything was fine except the tail was blown, which was apparently cutting power to the whole lighting system. Replaced it with an extra one and voila tails corners and halos all working again. hid's are still not working. Both head (l) and head (r) fuses seem to be ok, there is a big ass fuse right next to it labeled head, could it be that this one is messed up? Double checked all wiring grounds and connections its correct. Confused right now
Haha I'm an idiot the wire going to the ballast fits in both right side up and upside down, its just a 2 pronged ellipse...theres an engraved '+' signifying the red wire should be on that side but I didn't pay attention,l just lucked out and put both in backwards, we're good!
ian2328
