LC coil spring Color codes
Duhockey
ok,
so found some info on the different color codes found on LC fj80, fjz80 and LX470 coils,
not sure which are which, but
FJ80/FZJ80 Vs LX coil springs - Page 3
I want to know what color code you have if you have LC coils...
Im going to attempt to cross reference this info with toyota to get part #s to make this much clearer for those trying to order specific wraps...
another link with some info is here
Im trying to get some info compiled, so whats the verdict! what color code are on you LC coils and what are your measurements from middle of the wheel hub to the fender??
Ok so far, these are the members that have reported the color codes and some with the vehicle that the LC coils came off,
Duhockey- 19.5" Purple Green White 8 wrap- driverside
19' Double Purple light blue White 7.5 wrap- pass side
both off 93 LC fj80
FoneRunner- 19" Double Purple Light blue white 7.5 wrap - driverside
18 7/8 orange orange white 7.75 wrap - pass side
no vehicle specified
Rusm- 19.5" double Purple Green White 8 wrap -
19" Doupble Purple Light blue White 7.75 wrap
99Yota4- 21" Blue Pink White 9.25 wrap
21" Greg orange White 9.25 wrap
of a 91 LC (fj80 or fjz80?? )
GonzT4r- 21" Blue Pink White 9.25 wrap
91 LC (fj80 or fzj80 not specified)
Elton H - 19.25 Double Purple Dark Blue White 8wrap
SteezeMcqueen- 19.5" double Purple Green White 8 wrap - drivers side
Sn0wrunner- painted his all red, no help there!! :lmao:
LINY4runner- Too lazy to wash his truck and tell us! :)
So you dont have to search the thread for the color code info... I posted the quote from Ih8mud
"yep the color code is the definitive ID
Here is a list of color codes from the front springs I went though today
Height/color code/wraps
21" Blue Pink White 9.25 wraps
21" Grey Orange White 9.25 wraps
20.25" Blue Yellow White 8.75 wraps-one of these is a confirmed LX450
19.5" Green Yellow White 8.25 wraps-one of these is a confirmed LX450
19.5" Purple Green White 8 wraps
19.25" Double Purple Dark Blue White 8 wraps
19" Double Purple Light Blue White 7.5 wraps
18.5" Double Purple Grey White 7.5 wraps
18 7/8" Orange Orange White 7.75 wraps
From what we could tell all of the springs use about the same gauge wire. only 2 of these were from an LX450 so the LC and LX have springs in common at some point year like CDan has been saying all along, unfortunately I do not know what year belongs to what color code."
Good timing - I need this info, not that I can contribute anything but when it comes time to order the coils this should make it fairly straight forward.
19" Double Pink Light Blue White 7.5 wraps
18.5" Double Pink Grey White 7.5 wraps
you're welcome
what do LC coils run i may want to switch my 891 because i did not get the actual hieght that i was looking for but love the stiffer ride
I think that Katy ROCKI TOP AUTO (my wifes best friend) was shipping them for about 80$ a pair,
I know locally here there are shops in denver that have them for like 60$ a pair if you can pick them up.
I get mine from katy though.
Im gonna go look and see if I can see the color codes on mine, cuz Im sitting right about 39.5 in the back with mine, I think Steeze is about the same.
so these are prob mine then...
the 1st pic being Driver side, 2nd pic passenger
Drivers side then passenger side
i didn't get a picture but i have purple green white on the drivers side and orange orange white on the passenger. i think there is a little gangsta lean to the passenger but its not bad. i was at 34 inches ground to fender before the lift and i am now at about 39.5. i did have sagging springs though so i would say i got about 4.5 inches of lift
Anyone else??
I know there are more LC coils out there than me, steeze and fonerunner!
I need to know your color coding, and maybe post your measurements too...
Please?
thanks so much! :thanks:
Double purple- green- white
Double purple- light blue- white
40.5" ride height to middle of rear fender.
Guess what I have?!
I have the 9.25 wrap coils (blue/pink/white and grey/orange/white) They came off a 1991 LC. I'm picking up another set of coils from a 97 and I'll post up the color codes and number of wraps of those. I'm gonna try and install both of these and see which height I like best :D I also have TRD Tundra coilovers with the yellow billies on hold and should be picking them up Friday so I can finally get my lift started :)
You can't see the blue or the grey paint spot on the coil because I didn't clean them off thinking there were only 2 colors per coil like the TRD tundras.
DSC03660.jpg~original
H.Sikina
