Installation time
Singtoe
Here is a question for all you pros.
How long does it take to install a 3" (coil overs and rear springs) lift into a 4runner?
How long does it take to install an E locking Differential retrofit into 4runner.
Just trying to gauge my next projects and how much to expect the charge to be.
Honestly it really comes down to if you have the right tools and if you run into any stubborn nuts, bolts, etc, etc. Where are you located? Most of us here love wrenching on these things and are down to help a fellow member out.
Suspension is easy breezy, im sure someone on this forum would help, ~4 hours
Elocker would take awhile though, you have to pull the shafts, and the third, install locker and actuator, so your looking at the healthy part of a day there...
Tomorrow is the day. I will install the lift and locker at one shot.
I imagine the coil over will be a breeze for the front.
I will probably start with the rear first and see how it goes.
Starting Measurments.
Stock 99 4X4 limited 4Runner, 3/4 tank of gas.
RR 34 3/4"
LR 34 3/8"
LF 34 1/2"
LR 34 3/4"
Started at 8:00 am and at 2:00 finished the rear end work. All of it. The lift and the diff.
Put the front coil overs in this morning. Finished in 2 hours. I guess the whole job took me 8 hours. Just to give you heads up, nothing was frozen or rusted on.
Welding, Drilling and Tapping went smoothly with no out of misalignment issues. I was proud of myself when i dropped pumpkin into the axle housing. Fit like a glove.
IMG_0266.jpg~original
IMG_0267.jpg~original
IMG_0268.jpg~original
IMG_0269.jpg~original
IMG_0271.jpg~original
I used the Pumpkin as a centering jig to pilot my initial holes. See my crappy welds.
IMG_0273.jpg~original
Drill it out and tap it.
IMG_0277.jpg~original
Stud install
IMG_0282.jpg~original
Finally
IMG_0283.jpg~original
Woo hoo! Nice work man. That's quite a change going from stock height, no locker to being lifted and locked.
(Thanks for that trim btw, worked perfect!)
Last Monday, we installed a lift kit in Dous's 4runner and i want to say we did the whole thing in less then two hours. He had OME rear springs, shocks and Front strut spacers.
I guess practice makes perfect.
Afterwards, we had modify his gas tank skid plate to clear the drive shaft though.
Yea it went beautifully.
Nice work, I remember it taking my forever to do my lift the first time. Need to meet up with you Raleigh guys sometime. I come up there almost every weekend.
well seeing that this was brought up, how long do you think LC 8wraps and shocks would take? just those two. with a full lift?
