Urban Runner radio trim ring
i know the part is discontinued, but does anyone have any leads on a place that may have some old stock on hand to purchase from? part# is pz365-35904
thanks!
Good luck with your search. I just went through this search for the past month. Trying to order from any Toyota parts with an online presence to find none. At least now I think a lot of places have updated their sites to show not available. I ended up ordering the bestkit bezel BKTOYK961
thanks!
I have this if you want it. I pulled it off my 08 Urban Runner when I replaced my head unit
Sent from my iPhone using Tapatalk Pro
the 961 only works with the larger RDS radio opening, so it's a no-go for me unless i change out the whole center bezel that has the larger opening
Damn, that sucks. I was hoping it would work. I already ordered one :ybrick::ybrick::ybrick::ybrick::ybrick::ybrick:
do you know for sure your radio is non RDS? you may still have hope lol. post a pic of your dash and i can let you know for sure if the 961 will work
yup thats the same stereo i have, you'll need the basic metra or scosche filler wings that attach to the side of the headunit for our smaller openings
I'll try and figure something out with it since it's already on it's way. Might be awhile since I'm slowly piecing everything else together.
I ordered mine off Toyotapart.com and used this: PZ365-35904 PANEL SET, RADIO
RECEIVER (lbs: 1.5)
It cost me $89 plus shipping gave it up to $95 shipped...yowza but daaaaamn it looks right!
RECEIVER (lbs: 1.5)
Did you have any trouble making the head unit fit?
I want to replace the head unit in my 2008 Urban Runner and the first stereo guy I talked to said he would probably have to trim the surround some to make a double DIN fit.
I have the same truck and replacing the stereo head was one of the first things I did. If you have the UR you should already have the larger unit and there should be no trimming necessary.
No, The headunit fit in nice and the trim piece just slipped over it and completed the factory-like finish. I don't think any trimming will be necessary.
