Wiring harness in shifter concsole?
Jackkill1
I was replacing the t5 bulb in the console shifter indicator and noticed these 2 harness? Does anyone know what they are? I'm an 05 SR5 V8. Thanks.
I think I remember reading that they were for heated seats, but I am lit on cold medicine and could be wrong. Haha
Small one if for the inverter plug. Big one I think might be on board air, but not sure. I don’t think that’s for seat heaters though.
Looking at the 2007 Wire diagram the AC inverter has a two wire connector, one wire is red with white stripe and the other light green, so that top one looks like that circuit.
the other one i am searching for and will post if I find it in the EWD
The shape and color of the connector in the bottom pic, the 6 wire one, is the same as connector S24 and S25 in the 2007 EWD. If that is the same connector, then you should have 2 of them and they are for the LH and RH seat heaters and would power the harness to the seat. The wire colors are different than my EWD, but that could be just a year to year difference as your is a 05 and the EWD is for the 07. I thought it might be the air suspension but the connector shapes don't match up at all.
Maybe someone with the 05 EWD can see if the colors changed.
Thank you! I'm just now getting around to installing some seat heaters.
I was wondering this same thing tonight when I pulled the console apart. Thanks
Uhhh... I’ll pull apart my console and look, but that is definitely not the seat heaters. My limited’s seat heater connectors are in line connectors, not double stack.
Edit- actually, I’m almost positive that big connector is for the smokers kit.
That larger 6 pin plug has power to 5 pins, and gnd to one. They are on the 10 amp Cig fuse.
I am looking for the heater plugs, as the 4runner I just bought for my wife does not have the seat heater switches, but the fuse is in the fuse box, and has +12v with the key on. I am trying to find the power source for the heated seats, as I plan to use those for the USB power ports I am adding to the console and rear of the console for the back seat for my Daughter.
I cant find the diagram online anywhere. Does anyone have the wiring diagram for the stock seat heaters including the switches and wires under the seats? I imagine I will need to jump one or both of the switches so that there is +12v on the heater wires under the seats. I assume they are the large white wire with black stripe as he seat side of the plug has no wire at all, but there is no voltage with the key on, which is why I suspect the switch needs jumped.
Thanks in advance for the help guysl
delislerebecca
