Front end alignment specs after 3" lift
Outkastbaits
Just installed a toytec 3" lift but kept the stock UCA's. Going to a friend for alignment that works at Toyota. Since it has a 3" lift, are there certain specs, or just get it as close to stock specs as we can?
Get toe and Camber to specs. You'll probably have trouble with the caster getting to specs, so try to get the most out of that. If you can't get it to work then you will need to get UCAs.
Sent from my Pixel 2 using Tapatalk
Hello guys! Recycling an old thread to get your opinions.
I have installed a new lift (F3" / R3") and of course did an alignment afterwards. Although I understand the very basics of it I dont have enough knowledge to asses whether the shop did a good job and I should come back to them or if I should keep looking for a place I can trust.
Please see the numbers below and let me know what you think!
PS running an icon uca
alexhales578us
