Rear Hatch won't latch
rdruss
Have an '03 LTD with rear hatch automatic latch which decided to quit working and can't latch manually. Any suggestions will be appreciated.
mechanism is most likely rusted, can try cleaning rust off or replace the whole lock, happened to mine and replaced. can remove from the inside.
Got it to work! Moved it latch/unlatch with screwdriver and pressed open button and it responded, finally got it in right sequence to close/latch, hope it was just a glitch!
Thanks for responses.
