Lift/Tire/Spacer Clearance Question
Cubslover
Hey all, just took home an 03 SR5 V8.
I'm already ordering a leveling kit and tires.
Wheels are the stock 16x9.
Going with a 3/2 Fat Bobs Garage kit.
Will this lift alone allow me to clear 285/70/16s without spidertraxx or will I get a bit of rubbing without them?
Thanks in advance.
I have the Toyec Ultimate 3" Lift, I run 285-70-17. No Rubbing under normal Driving... But turning and With Full wheel articulation I will rub the wheel well... So I had to trim the wheel well... And My wheels are offset pretty good though..... HTH
Thanks in advance.
I doubt the stock wheels are 9's. if yours are9's, they're prolly aftermarket.
Depends on the type of tires you have, but you more likely won't rub with stock wheels during regular driving on a 3/2 lift. Might rub a bit in full rank turns, backing up, etc..
