Straightening hitch safety chain ear
Rubberdown
My hitch safety chain loop is bent. My wife pointed it out to me again. I guess that means fix it.
If I remove it and heat it up and beat it nice and straight ( looks thick as hell, it may be hard) is it going to weaken the metal to a point where I ought to worry if god forbid I did actually loose a trailer? I don't really do a whole lot of metal fab so I'm not 100 percent on doing it.
Other scenario: anyone put on a ear bumper and want to sell me theirs?
can you get a pic of it?
how did it get bent?
She's at work I can snap a picture tonight.
My wife has this annoying habit. She loans her car to her parents all the time. They do not give a flying rats butt about cars. Her dad took her car on the farm, and decided he wanted to pull down a dead rotting tree. I have no problem with that. But, he took a tow chain, hooked it on the ear, and pulled it down. Which bent the ear. There was a freaking hitch shackle in the bag o goodies but noooooo. F up my car. He also backed into a aeromotor windmill with it. Yay scratches. God forbid I tell my wife to tell him to take his own pre destroyed wrecked junker.
Don't heat it up.
You should be able to bend it back with a sledge hammer (BFH Method) if your careful, a little at a time. I would try that first and then spray some rustoleum on the scratches.
Ahhhhhhh grammar police! Yeah I will put my pry bar on it tonight and see if it moves. I'm scared of my 6 pound sledge... I hit my hand twice with it sat. trying to fix the door frame on his truck so the mirror would bolt up flushish after he ripped it off on a pole.
If the loop is bent down you can simply use a jack to get it back into place. If the loop is pulled backwards then, as [MENTION=65614]Antman[/MENTION] suggested, a BFH is needed and 6 lb might not be enough.
If your wife can tell that it's bent, it must be really really bent. I suggest hitting her dad with the 6 lb hammer first to get it warmed up before striking your hitch with it. I've read that this would help with accuracy.
That would also help with it not getting re-bent
Yeah it's pulled to the rear. The bottom is about an inch back
LOL grab yourself a 4x6, 6x6, or similar chunk of cribbing a couple feet long, put a small v-notch in it, back up to a wall, grab chains and a bottle jack, chain the truck in place to said wall, put the base of the bottle jack against the cribbing and jack away :D It is just as safe as trying to smack it with a sledge!
What the frig kinda wall do you have that you can chain your truck to it, and a bottle jack wouldn't just push through? I could do this with the storm drain in front of my house maybe. Not a bad idea
Concrete parking garage or similar :) it is solid and has pillars you can wrap a chain around. I have straightened a few things out this way. Square steel tubing, small I-beams, and such. A little different but principal is the same.
