BlackVue Dash Camera Installation (DR650GW-2CH)
Fenix84
So, I've been in the market for a dash camera for awhile. Since there are so many different cameras out there it was hard narrowing down the model that fit my requirements. Those being...
1. Dual Camera (Front and Rear)
2. Discrete and small
3. Captures video 24/7 even when the car is parked
4. High quality video (1080p)
5. Motion Detection
6. Light weight
7. Has great reviews
I ended up with a BlackVue dual camera system. They have a number of dual camera systems but this one is all black and fits nicely on the windshield where it doesn't obstruct my vision or garner unnecessary attention.
In addition to the camera I purchased the Power Magic Pro system which enables you to hardwire the camera system to the vehicle. So even when the car is powered off it continues to monitor and record when the motion sensor or g-shock sensor are triggered. The unit also does other things too such as provides the user the ability to specify how long the camera will run for after the car is turned off and automatically turns off the camera system when the battery voltage reaches a certain level. In my case I have the system set to never shut off and have the auto shut off kick in when the battery reaches 11.6 Volts.
The installation is pretty straight forward but I thought id take some snapshots incase someone was interested.
1. Mounting the front camera. I mounted the camera in the center of the windshield (of course) underneath the mirror. The great thing about the blackvue cameras is that they are tiny and can get into tight spaces. In one of my photos below you can see the view from the driver side. For a 5' 10" guy like me I cant even see the camera. Of course this is somewhat dependent on how your adjust your seat but for me its perfect.
The camera mounts with double sided tape, it sticks very well and if needed it comes off clean with no residue. The package also comes with extra double sided tape incase you need to readjust something.
2. Power Cable Wiring. I began wiring the system from under the dashboard on the drivers side. The first step was to remove the driver side airbag pillar panel. Its pretty easy to remove just needs a little force and some pliers. Start pulling at the top of the pillar until the fastener releases. Now you will need to get yours pliers behind the panel the twist the remaining fastener to release the pillar (A flashlight will really help here). Once that is done the panel should come off no problem. A part of the air bag will still be attached to the pillar, there is no need to disconnect it. From here you can run the power cable.
The idea here is to run the cable from underneath the dashboard up to the top of the dashboard. The reasoning for this comes from the fact that the power outlet is much to large to fit through the holes between the windshield and under the dashboard. You will need to drop a weighted line from the top of the dash board to under the dashboard. This way you enlist the help of gravity and will be able to fish the small end of the power cable up through the dashboard.
Once you have the power cable figured out you can connect the cable to the front camera. Run the wires up into the headliner and tuck the wires between the headliner and the front windshield. There is more than enough space and the wires will stay put. For extra security you can add some cable clips or whatever you like, just make sure the cable and clips are out of sight. Also be sure to leave some extra slack for when you want to detach and reattach the power cable to the camera.
3. Connecting the Power Magic Pro. Since I am hardwiring the system I decided I would connect the ACC, Battery and Ground cables to the fuse box in the engine compartment instead of the fuse located under the steering wheel. Either way will work but for a cleaner install the engine compartment works better when adding fuse taps. The fuse box under the steering wheel is pretty tiny and with fuse taps connected the fuse box wouldn't be able to close.
Of course I'm just making work for myself but at the end of the day I'll be slightly happier. So in order to get the cables from under the dash to the fuse box in the engine compartment the Battery, ACC and Ground cables from the Power Magic Pro (PMP) are going to have to be extended. Don't extend them yet!! The cables are roughly 20 gauge but since I didn't have any I used 18. Its ok to go with larger wires but not the other way around.
The trickiest part of this entire installation is running the cables through the firewall. The idea is pretty simple but actually doing it is much tougher. The hole in the firewall is tiny and will take some pulling to get the cables through. I noticed there was an unused route and decided to use that one, you can see it in the picture below. I straightened out a metal clothes hanger and used that as a guide for the cables. I taped 3 new cables of appropriate length (Power, ACC and ground, also be sure to label them) together the then taped them to the hanger. I started feeding the wires from inside the engine compartment towards the inside of the cabin. Once you can spot the wires from inside the cabin you can gently start pulling them through. Now just attach the new cables to the existing cables on the PMP.
4. Connecting the cables to the fuse box. At this point you can start connecting the cables to the fuse taps. If you don't know what a fuse tap is heres a picture.
3
You can find these anywhere. Just make sure to get a fuse tap for Mini Fuses. Also grab some 10 Amp fuses.
Once the taps are connected, add the fuses to them and connect them to the fuse box. Here's a diagram of my connections
FYI: ACC - Power when the car is on
BATTERY: Constant Power all the time
Remember to connect the ground too!
Once the connections are made its a good idea to cover the cables with some form of protection. I used this.
5. Testing the Power to the Power Magic Pro. Now you can connect the main control box of the PMP and turn it on. If the LED lights up then you are good. If not then go back and figure out what went wrong.
6. Wiring the rear camera cables. This part is a lot easier than it sounds, it probably takes no more than 10 minutes but take your time cause you don't want to wreck the cable (you only get one!). Tuck the cables under the plastic window trim where you can and gently pop off some panels where you can. The pictures below are from after my cables are installed so you can see that it fits pretty well. Be sure to connect the rear camera cable to the front camera before starting.
7. Rear Camera Mount. At this point you are probably wondering where you are going to mount the rear camera. Most people mount their cameras to the back windshield but that isn't something we can do since we'd lose the ability to open and close the rear window.
I ended creating a mount that goes on the headliner. Its not the most elegant solution but it works. The rear camera weights 15 grams so it doesn't need much support. All that is needed is something light weight and not very flexible. I ended up using a thin aluminum sign I got at the hardware store. I cut it to size with some shears (10cm x 4cm), sanded down the edges, painted it, add some Velcro to one side to prevent the mount from moving around. The Velcro proved to be strong enough to hold the camera but for some added support I drilled a hole through the middle and ran the headliner clip through the mount. Removing the clip from the headliner may ruin the clip but they are cheap. I bought 25 of them from ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners for 7 bucks + shipping. The pictures below illustrate the entire process. The total weight of the rear camera and mount was 22 grams, so there shouldnt be any problems supporting the weight.
8. Mounting the Power Magic Pro. And finally mounting the PMP. The unit comes with some double sided tape and all you want to do is mount it where ever you like. I have mine here.
Well hope this helps someone.
Thanks for reading!
Very cool! Is it motion activated recording?
Its recording all the time. When in "Park Mode" it records but doesn't write to the SD card unless a motion is detected. When a motion is detected it writes the event and 5 seconds prior to the event.
Events can be configured to be 1 minute, 2 minutes or 3 minutes.
The G-Shock sensor and Motion sensor sensitivities are adjustable.
Yup I believe its the Blackvue DR600GW-HD.
I don't know anything about it, but it appears to be very similar.
Sorry for the old post revive. Fenix, not sure if you know the answer to this.
I just finished adding my fuse taps and grounding for the Power Magic Pro. I did the fuse taps in the kick panel below and to the left of my steering wheel on my 2007 Sport. That made finding and getting access to a good ground bolt a giant pain in the butt.
Anyhow, I got everything plugged in and then tested the Power Magic Pro. The power switch was already in the "on" position. When I flipped it to the "off" position, the green LED stayed lit.
I think the point of the Power Magic Pro box it to keep it on so that it can regulate the power draw of the cameras. But I'm sure there will be some occasions where turning it off would be beneficial. Any idea whether I need to be concerned about this or how to fix it? My guess is that I just need to replace the Power Magic Pro box with a new one.
You can set a certain preset time of how long you want the PMP to supply power to the cameras before shutting off. On my 1 car I have it set to 48 hours before it shuts down but that's bc that car is mainly in the garage. I have the one in my 4Runner set to 72 hours since that one is parked outside most of the time. Once you start the vehicle it resets the time again. Also, the PMP monitors battery levels so if there's a sudden drop in voltage, it will shut off the supply to the cameras so as not to drain any more battery. HTH
Thanks Chudiddy. I'm aware of most all of that. one of the things I'm not certain of is the behavior after whatever time frame when it shuts off. Is that when it goes into parking mode? I assume that after that period of time, in your case 72 hours in your T4R, it doesn't record at all.
I thought that part of the appeal of the PMP is that in parking mode the PMP allows the cameras to draw minimal power, and only kicks into 12v power draw when motion is detected (with various levels of motion sensitivity selectable in the app).
Any thoughts on that? Do you have your PMP on all the time except for when it shut off because it "times out"?
Hey, opps sorry for the delay, didn't see your question till now.
You are right after 72 hours chudiddys camera will not record anything.
When its on, its in either park mode (GPS location static) or normal mode (GPS location changing). When its off its completely shutdown and wont record or monitor anything.
Park Mode means the camera is running but NOT recording. Only if something triggers the shock sensor or triggers the image sensor will it record the event to the SD card.
Normal Mode, records all the time while you are driving.
The purpose of the PMP is to save your battery. I run mine on all the time until the voltage reaches below 12.6 volts then its stops monitoring.
Hope that clarifies things.
Nice write up. How about a long use review? Whats the funniest thing you captured, scariest?
How does it switch between modes?
I've had it since the summer and so far so good. It's very reliable and has not let me down. The PMP works great too and ensures I don't drain my battery.
It's basically everything it said it would be, no surprises really.
The unit has Wi-Fi so you can connect to it with your smartphone to view old videos, and watch either camera live. Works great when you want to review an incident that just happened, thankfully I haven't had to do that yet.
The video quality at night seems pretty good to me, so no complaints there. And of course day time video is very clear. The wide angle lenses comes in handy too when viewing objects more along the side.
The camera comes with some pretty good viewing software which let's you view both cameras simultaneously as well as tracks your GPS location on a map. Pretty spiffy.
The one thing that was disappointing was the sensitivity of the camera sensor in park mode. It's super sensitive no matter what sensitivity setting you have it set to. I later learned it's normal for all camera sensors.
As to the question how it switches modes? I haven't quite tested this out yet so I don't know for sure. It's either the built in GPS sensing that the car is moving or the unit sensing when the acc power has been turned off. It's one of those or a combination of both. However it is doing it it seems to work perfectly... it always seems to know.
I don't know what the funniest thing I've captured but I have seen cars slide on ice and bump each other. Also lots of animal videos since I drive in the mountains.
The scariest is probably driving in storms where I can't see past the rain. Also this NYE I almost smoked a car that decided to switch out of an exit only lane at the last second without signalling.
All in all I'd buy it again if I got another car.
I feel bad, even with the Power Magic Pro and the present of a Optima Yellow top... Mine still shuts off after 12.6 volts. I feel like an idiot running my Battery power down low.
your review and write up are freaking AWESOME! just bought this kit w/ 64GB memory card and free PMP from blackboxmycar.com limited time sales event, and used discount code newyear10 for $10 off. ~350 USD (509.99CAD) shipped! Also read nothing but good reviews from them as a vendor.
I'm gonna follow your write-up to help me complete this! Thanks man!
Howd you get it for $350? Best I could get them to was $439 and that was for 16gb ETA nevermind the yare a canadian website.... 64gb is $321 USD shipped
Great write up!
Does the tinted glass and the distance of the rear cam from the glass reduce video quality? Also does the spoiler's shadow affect video quality? Thanks!
Good photos and good idea on mounting the back camera.
I'd love to see some video however. Especially rear facing video.
