Install of 5th Gen Hood Scoop LED Lighter
Mean TT
So it can be done, and I had it done.
The trick to installing a LED Lighter in a 5th gen hood scoop is finding a LED Lighter that is low profile. I was able to find a single one that worked.
Here is a link to it:
http://www.amazon.com/u-Box®-Cree-13inch-3600LM-Light/dp/B00VM4OQBM
The next step is to grind down the metal on the side of the Light bar so that it is flush. the reason for this is because it really doesn't fit as is. The opening on the 5th Gen 4Runner hood scoop is about .75 inches and the light bar is 1 inch plus another half inch for the raised sections on the sides of the bar.
Once you grind off the edges, will still need to mark and cut .25 inches off of the hood scoop to get extra clearance on the top if the scoop to mount the bar.
Once you have it sized, you will have to make a custom bracket which is pretty simple. The danger that I foresaw was that I needed this to be waterproof because the insulation on the underside of the hood does not have a cut out.
The solution was to put a bead of silicone around the bar to seal everything up.
The bar that you see in the pics is a flood set up. If I had it to do over again, I would probably have gotten a spot arrangement. A lot of the light is going up. That said, the Rigid Dually's are so good that I don't know if it can really be said that this mounting is worthless. I think that this set up is best if you believe you will be creeping through branches or there will be a lot of forward and back pitch where you are driving so that you can see whats coming.
20160407_200125_zpsiq9uyjlz.jpg~original
The second shows it a little better.
20160407_201831_zpsajmvotgn.jpg~original
The DRLs are a custom set up I purchased off an Ebay Seller. I really like how they transform the look.
Let me know if you have any questions.
this looks like a pretty neat idea. would you happen to have any more pics? specifically, how you have it mounted?
thats pretty cool I was wondering though,what about the light it throws on your hood. It seems as if you would get a glare off of your hood. can you see the reflection at night when you are driving? I have a 2000 sport that i want to do that to and i brought home a new trail premium today and well you guessed it i want to do it to that too. I was kind off thinking about sandblasting the inside of on acrylic tube and stuffing it with led strip maybe even r g b just for the hell of it . the tube would act as a diffuser and silicon would seal the ends. mount the receiver for the remote in the cab... the tape comes with a remote and you have many options for color. I used the r g b tape for a dartboard cabinet that i made
I may take some more. You mount it to the 4 screws that hold the scoop in. However the hood has single use plastic rivets that hold the insulation to the hood. So I would have to order a new set to take a photo of the underside.
No glare from the hood while I am driving from the driver's seat. However because the flood beam was like 60 degrees, a lot of the light gets zapped given its close location to the hood. Hence a spot or a combo arrangement is the better option.
I played around with other Led arrangements. You have to have reflectors to make it work properly. Otherwise it has no practical effect. Like I mentioned, the 1 inch led light strip is the only think I think will fit without major surgery. Good news is that it's cheap, 30 bucks from eBay.
I've considered an amber LED strip, like as sort of a marker light... but damn that's intense. I'm more surprised that they make a light that bright, and small enough to fit in there.
look at Super Bright LED they make some nifty stuff. I did this to a dart board. I got 16 feet of flexible r g b . It came with a remote so I can control color, speed of the flash control ,it has a couple of different strobe and chase patterns ... pretty cool. took the better part of a day to get this all assembled. fun project.
any way this is what i was foolin around with tonight
I tried those as well. Although they are bright the light doesn't project. They would make ideal backup lights or undercarriage lights. Best of luck though.
I haven't had much time on the rig, will upload pics tomorrow.
What lighting setup do you have for the grill? Is it inset or mounted on the bumper?
It's a rigid 20 inch spot and flood combo and the grills are rigid as well, not stock.
The performance is great, but it does create a little bit of a hot spot on the road/trail. Hence, the roof mount lights will be a "necessity".:hurt:
Every time I look at my hood I feel like it's missing nightrider lights:
I found some that fit but couldn't figure out to mount and wire
stc6306
