Not Happy With CH4x4 Switch, Should Have Gone with AOB
Just ordered my third spot light switch from OBA hopefully it will last more than 1 month. I emailed them about a fix but Craig was no help.
this will be the last I will figure a work around and let you guys know
Waiting on a Sasquatch Light from AOB to finish my ditch light install. I ordered a backup from CaliRaised LED in case the AOB is trash. You'd think something this simple wouldn't have so many issues.
I just replaced my CaliRaised ditch light switch with an AOB. The CaliRaised only “fit” with a few wraps of electrical tape, so the reduced resistance made it more difficult to switch lights on/off on the fly. AOB fits much better for me.
CH4x4 works perfectly for my compressor. Initially I assumed it was faulty because it did not stay switched on and acted as momentary switch but I discovered 4Runner's switch panel has few plastic edges where this switch goes in that prevents this switch to be pressed fully. After few minutes and razor blade mode to panel it works perfectly.
Yes I'm replacing my caliraised too on my 2020. 2 of them failed after maybe 2 months of barely being used. They would just stay pushed in.
Looking at the other options on this thread! Thanks.:iagree:
I ordered an AOB switch that was wired incorrectly from the factory. Frustrating as hell to spend hours wondering why my wiring wasn't correct, only to realize that it hadn't been done correctly at the switch from the factory.
