Anyone running OME springs?
3rdgenfan
Thinking about ordering some OME springs. Looked at getting the 884 for the front and 889 for the back. If anyone is running this setup would like to see pictures and there likes and dislikes with the setup.
I do already have bilstein 5100's on the front. Still running stock rear shocks.
Will it be ok if don't upgrade my UCA yet? Won't be doing any hardcore in this. It's my wife's just trying to lift it up. Got a set of trd pro wheels with 285's on them I am putting on it.
Literally hundreds are running OME springs. Did you try searching?
Anyway here is mine 3" all the way around.
Yep. And if you get the springs I would advise getting the matching shocks otherwise you will be topping out the stock springs on every bump in the road.
His sig line says he's running 5100's. I have 885's on the front with Toytec +10 Superflexes in the rear. I have the 885's to offset the extra weight of a slimline bumper and winch. Completely happy with the handling. I got the Toytec's used off the for sale thread, but I imagine similar OME's would have been about the same for me.
I am still running the stock shocks in the back. Thinking about upgrading to the one shocks for the rear. Are you running aftermarket UCA?
I have some OME 889s that I haven't put up on the F/S thread yet...
Had them on the back with 5100s and pulled them off because the rake was too much (6112s in front).
Only had them on for about 1K miles.
No, I am still running factory UCA's. "I gotta guy" here who actually adjusted my LCA for maximum caster and then set everything else after. I don't think the Toyota techs who installed the shocks in 2014 messed with the lower arms at all. It does track better than it had in the first 2 years, but he didn't give me a printout. And I'm only at 2".
i have 885/898 on 5100s
The 885s are fine without the extra weight needed for them, but the 898s are being swapped out for 889s.
I'll probably end up with a front bumper before a rear bumper.
